Upgrading stock sub
Old May 9, 2011 | 11:25 AM
Prestige_Worldwide's Avatar
Upgrading stock sub
I am looking get more punch out of my stock setup. I have the optional Pioneer system but I want more bass and I heard replacing the factory sub is a good start. Anyone have subs they recommend, I heard these were good but there are no local dealers near me.
Link >
Old May 10, 2011 | 03:16 AM
EmperorJJ1's Avatar
the rockford p3 shallows are pretty good
Old May 10, 2011 | 07:59 AM
Thanks, I checked their website and I don't see any 8"s, will a 10" sub fit in the stock enclosure?
Old May 10, 2011 | 10:37 AM
EmperorJJ1's Avatar
ya its a 10" in there now. might need a lil trimming of the box to make it fit but a few peeps on here are running them with great results
Old May 10, 2011 | 10:54 AM
CobawLT2010's Avatar
Was going to say run a Fosgate... but im a bit biased since my Balt has 2x12 inch Fosgates...
Make sure u get a better amp and put it in the stocker amp isn't going to push a new sub around... but keep the stock amp for the speakers...
Old May 10, 2011 | 11:20 AM
Can you just upgrade the stock amp to run everything? I suck when it comes to any audio equipment installs.
Old May 10, 2011 | 06:28 PM
HmF300ex's Avatar
Don't get Kicker CVT's, they are 10" and shallow but the mounting circle has a plastic rim on it and it probably wont fit. Are you replacing the stock amp? If not, I don't see why getting a powerful sub would be beneficial. I have a couple new boston G1's that would work great if your not getting an amp!
Edit: And no, you can't upgrade an amp. I don't know what size the stock one is, but adding a different sub will help A LITTLE as it may be more efficient/draw more power from the stock amp, it probably won't distort at higher levels with the bass turned up and it may hit lower notes. But not a large difference, not much more thump. If you want loudness, gotta get an amp/sub combo. If your replacing the sub make sure the stock box's volume dimensions match up with the subwoofer's suggested volume, having the right box/sub combination can make or break a system.
Old May 10, 2011 | 06:34 PM
SSmokie the bear's Avatar
the time, money, and energy you would spend trying to "upgrade" the stock system will not produce enough benefit to make it worth it. i would take a the money and energy and spend it on replacing stock pieces instead of "upgrading." the reason I say this is because the stock box was not designed to do anymore than what it is doing now. Putting a new sub in a stock (crapy) box wont help much. Also, more than likely a new sub would require more power than the stock amp is capable of making. i would say use a line converter and get a new sub and amp if all you want is more bass.
Old May 10, 2011 | 06:37 PM
bbrewbaker's Avatar
I have a shallow Memphis 10 inch sub in mine.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
