why is my amp shutting off!!
Old Jun 26, 2007 | 04:00 PM
widebody_balt_ss's Avatar
i have been trying to figure this out all day. whenever i turn up the music the danm amp shuts off. i have had 3 systems in the past and done my homework on car audio.. i am stumped. i changed my remote wire to an acc. wire, did nothing. i turned the volt sensitivity down... helps a little. but not much. if i turn it up just a little more the amp goes into protect mode. then i turn the cd played down and it turns back on... im pretty sre i have a good ground too.
Old Jun 26, 2007 | 04:21 PM
shawns94's Avatar
Your amp probably has a OHM Cut off so that it won't ovrheat most are set at either 4 ohms or maybe 2 ohms. Do you have dual voice coils on your subs? If so you will have to find a diagram that will show you how to wire them so that they are at 8 ohms and then run them parallel on the amp to bring them at 4 ohms.
I had to do this to mine anyway.
Old Jun 26, 2007 | 04:22 PM
the subs are dual v-c 1 ohm stable. the amps are supose to be able to run at 1 ohm. i will look at the box again. hold on a sec.
Old Jun 26, 2007 | 04:24 PM
shawns94's Avatar
its not that the subs can't handle it. The amp most likely will go into limp mode if you go under 4 or 2 ohms you need to read up on your amp.
Old Jun 26, 2007 | 04:26 PM
ok, what i have are the kenwood kfc xw100 2vc 10inch woofers they are from the excelon line. i have them ran from a 2 channel excelon kac-x812d amp. i have ran them straight one channel to one vc. and i have tryed running them bridged too. it just keeps shutting off. i have two of these amps and both do the same thing..
Old Jun 26, 2007 | 04:27 PM
slowbalt19's Avatar
what you are doing is asking the amp to perform outside of its ability which is causing the amp to clip out, and what brand amp is it, most say the are 2 ohm stable but the heat produced by that little of resistance causes it to thermal protect which sounds like your problem, and im sorry but i have never seen any kenwood run 1ohm stable. the problem lies in the ohm load of the subs, make sure they are wired no lower than 2 ohms, what is the ohm rating of the subs voice coil.
Old Jun 26, 2007 | 04:29 PM
ok, where should i look to find how to wire them 2=2 ohm"?
Old Jun 26, 2007 | 04:33 PM
shawns94's Avatar
Ok what OHM are they running at (subs)? Because with the dual VC Subs can be wired to run 2 4 8 ohms.
Old Jun 26, 2007 | 04:37 PM
right now i have taken the speaker wires from the amp, i can run them any way now. i think i was running them at 4 ohms.
i like that head unit by the way. (your pionnier.)
by the way. just so you know im only talking about one amp and one sub here.
Last edited by widebody_balt_ss; Jun 26, 2007 at 04:37 PM. Reason: Automerged Doublepost
Old Jun 26, 2007 | 04:42 PM
shawns94's Avatar
Thanks, and I am not real familar with kenwood you might have to do some research and find out exactly how they should be wired up to the subs.
slowbalt19's Avatar
wire the sub in series
Old Jun 26, 2007 | 05:47 PM
i got it to work. thanks guys
Old Jun 27, 2007 | 01:26 AM
EmperorJJ1's Avatar
damn u guys are making this difficult answer this
A. Amp model number and ohm stability
B. Sub model number and ohm rating (u said dual so probably dual 2 or 4)
Old Jun 27, 2007 | 04:12 PM
Boltin Balt's Avatar
^ need to know. Also check your ground. Very comon for what you are descibing to be a loose or insuficent ground.
Old Jun 27, 2007 | 04:18 PM
cblt12's Avatar
thats what i was thinking
o **** i just saw you got it to work, what did you do?
06MetallicBalt
Jul 20, 2025 08:47 PM
The Rookie24
Jan 20, 2016 05:14 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
c_m_shooter
Sep 27, 2015 04:40 PM
roth
Sep 26, 2015 12:16 PM
