wiring question and fm modulator
Old Jan 11, 2006 | 02:29 PM
hardtocope's Avatar
i'm going to be wiring the remote wire from my amp to the cigarrette lighter power.. since it has consant power i will be needing a switch. the switch has a power, accessory, and a ground. since my remote wire does not have a ground what do i hook the wire on the switch to? also i'm going to be wiring a fm modulator the same way to my cigarrette lighter. has anyone used a fm modulator on their cobalt yet? are they safe?
Old Jan 11, 2006 | 07:53 PM
Bandit2941's Avatar
Why do you want to wire it to something with constant power instead of something with switched power? Why not just tap the wiper or sunroof fuse for switched power?
Old Jan 12, 2006 | 12:24 AM
05stockbalt's Avatar
don't even bother hooking it up to that there are tons of posts on here for where to find acc power there is even a how to on this subject...as far as an fm modulator there is really nothing that can go wrong unless the modulator goes bad...should be fine
Old Jan 12, 2006 | 02:11 PM
hardtocope's Avatar
well there is really no real acc wire in our cobalts. i could hook it up to the windshield wiper fuse but that is connected to the body control module and i don't want to run into problems. the cigarrete lighter is there to add accessories so tapping into the power of that and putting a switch on it is a good idea to me. but everyone has there opinions. i'm just worried the fm modulator is going to sound like crap.
Old Jan 12, 2006 | 05:32 PM
Redberet's Avatar
Running off the wiper fuse will not hurt anything. That being said, if you still don't want to run off wiper cct, you can wire it up the way I explained in another post. Run a trigger wire from the brown wire coming off the ignition switch and run it to a relay powered by the battery. Thats the way I had mine ran before getting an aftermarket head unit.
Old Mar 19, 2006 | 11:54 PM
iLLmaTic3s's Avatar
u would never want to put that to the cigg. plug. andhave a switch..its a waist of time..hit it to the fuse box and find a fuse that turns on and off with the. ex(sunroof fuse). i have a fm mod uatlor in my cobalt..its fine for the..yet i put mine to the cigg. wires. and ihave a swtich mounted by my steering wheel. the radio isnt to bad to take out. go for it.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
jmelton327
Sep 26, 2015 10:04 PM
reybalt
Sep 25, 2015 08:28 PM
