wondering if my ECM is bad
Recently replaced my clutch and everything went fairly smoothly but when i took it for a test drive, i have no speedometer, the shift gauge doesnt read what gear im in, i have no engine temp sensor, and my fan turned on and wouldnt turn off until i unplugged the battery. is there anything it could be besides the ECM? it doesnt seem to be running like **** and it idles perfectly fine. any ideas help, because im out of ideas. i checked any fuses that would make sense.
Doubtful that it's the ECM; more likely that it's a loose connector on the bottom of the fuse box. Did you use the fuse box removal method to drop the transmission? Potential problem with grounding, as well, but I think that'd be less likely.
Naresh A Sookraj
Sep 19, 2017 05:03 PM
1BADSS/SC
Apr 17, 2007 04:35 AM
