Xenon HID PnP Kit Question
I ordered a Xenon kit, thinking it was a bi-xenon kit.
Is there anything I can do to customize the wiring to make the xenon wiring kit the same as the bi-xenon kit?
Also, I am having trouble finding bi-xenon kits for the cobalt ss, could you kindly post some links here? (if it's impossible to modify the xenon kit)
Also, for the sake of clarity..
I'm ultimately trying to get the low beam and high beams to work together (at the same time). I have a gen 3 projector housing from 3b specialties, and both low and high beam are H1's.
If you have gen 3s you ordered the correct kit. A bixenon kit would not have worked. Search the how to section for the ultimate high beam mod. It tells you how o make a relay setup to get both the lows and highs to work at the same time
Awesome, thank you for the info.
I'm happy I ordered the right kit, just need to run a relay to keep the lows powered while I run the highs.
I'll search the forum for the mod, cool.
Thanks!
Thanks!
https://www.cobaltss.net/forums/appe...read||-203962/
Gen 3 take H1 bulbs for both high and low
you will need 2 of these H1 HID Kit
I understand what I need to do, just trying to sort out the details. So, I will use the relay to enable the HIDs while the high beams are on (and low beams normally off). The sense wire for the relay will use the positive of the high beam, but not sure where to put the output of the relay wire back into the HIDs.
I know how they will work seperately, but somehow the relay that will get energized by the high beams must tell the low beams (HIDs) to remain on.
09-28-2015 12:51 PM
