Forced Induction Turbos/Superchargers
ac delete kit with stage 2 sc belt size
Old Feb 17, 2014 | 06:26 PM
Skullz666's Avatar
I wanted to know if anyone has/is running this setup? If so what's the belt size or any ideas on what I can to make it work
Old Feb 17, 2014 | 07:17 PM
EXsoccer1921's Avatar
If you're going to delete it, get rid of it completely. Even with gutting the compressor and just running the front pulley there is still a lot of resistance. Let me see if I can find the video.
Old Feb 17, 2014 | 07:28 PM
Skullz666's Avatar
No I'm going to completely remove compressor
Old Feb 17, 2014 | 07:38 PM
redcobalt07's Avatar
remove all the lines too, you'll get a lot of weight savings too.
Old Feb 17, 2014 | 07:47 PM
Skullz666's Avatar
I plan on doing that just want to know what size belt would work and maybe if the base model belt might work for this application
Old Feb 17, 2014 | 07:48 PM
I'm not sure of the belt size you'll need then. Base model won't work because they don't have the supercharger. Would work if you're turbo though..
Old Feb 17, 2014 | 07:55 PM
Skullz666's Avatar
You don't think since I'm removing the compressor completely and going with a smaller pulley it might work out maybe the one with the a.c. belt might work
Old Feb 17, 2014 | 07:56 PM
What?
Old Feb 17, 2014 | 08:00 PM
Skullz666's Avatar
I fixed it lol sorry on my phone and driving lol
Old Feb 17, 2014 | 08:04 PM
It's the routing that will get you.
Old Feb 17, 2014 | 08:06 PM
Skullz666's Avatar
Ok any idea what I could run even if it's another car that runs smaller belt
Old Feb 17, 2014 | 08:56 PM
mongorat427's Avatar
Run this. Its an actual AC delete from GM very Rare
Old Feb 17, 2014 | 08:59 PM
Skullz666's Avatar
Ok how much but I rather do this without running this I'm trying to just get the belt out if anyone could tell me if another car that it might be the same on
Old Feb 18, 2014 | 07:29 AM
blueLNFftw's Avatar
Take it out, grab a string, and route it as the belt would be. Tie it and then take it off. Measure it and buy that size belt. Post up the size for future member's questions. Sometimes you have to be the pioneer.
Old Feb 18, 2014 | 07:41 AM
jrmotosports 88's Avatar
with supercharged cars there is no possible way to remove the pulley position of the ac delete. you must have that contact area for routing reasons. to delete the ac you need to gut the compressor like mongo has pictured. the weight savings is only in rotating mass, the lines and condensor weight next to nothing. the guts of the compressor must weigh at least 20 lbs. the biggest benefit is getting fresh air to the stock heat exchanger. i recommend doing it if you can live without the ac.
turbo charged cars are completely different. it is as simple as a belt replacement and removal of compressor, condesor and lines.
Old Feb 18, 2014 | 07:49 AM
also i forgot there is no change in belt size that your currently using. your not changing a thing in distance of belt travel. it makes no sense to put a smaller pulley there. it will essentially become a idler pulley.
Old Feb 18, 2014 | 08:02 AM
Skullz666's Avatar
Oh ok cause Tim from zzp said they did a delete kit but not allot of people ordered it so they didn't continue to make it and yea I can live without ac lol I've never used it an any car off been in
Supercharged06SS
Dec 11, 2022 04:47 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
