Forced Induction Turbos/Superchargers
Adjusting the bypass valve
Old Jun 19, 2005 | 11:07 PM
MarcS's Avatar
The Stig
Question Adjusting the bypass valve
Does anyone have advice on adjusting the bypass valve to allow full potential boost, or to allow full boost sooner than what it is currently configured to?
I've read on other threads of people hitting 12.5-13psi. Even 1psi of boost can make a good hp difference.
Old Jun 20, 2005 | 01:06 AM
zinner's Avatar
Moderator Alumni
You may very well get the boost to come on sooner, but the PCM can also vent extra boost and override the calibration on the bypass valve.
Old Jun 20, 2005 | 01:08 AM
3fo893013L's Avatar
First person to get around this loop hole w/the bypass valve(on our cars) and succeed without blowing there motor up and run 18PSI on the stock Eaton blower gets a gold star in my eyes.
Old Jun 22, 2005 | 01:56 PM
2K2CamaroSS's Avatar
Where is the BPV located??
Old Jun 22, 2005 | 02:20 PM
MarcS's Avatar
The Stig
It is attached to the SC on the right side.
Old Jun 27, 2005 | 02:49 PM
ray@revitup's Avatar
we ran 13 psi on our cobalt by removing the vacum line on top of the valve and moving the one on the bottom to the top. a few weeks later it = check engine
Old Jun 27, 2005 | 03:06 PM
RAZOREXPRESS's Avatar
my ss is boosting 13lb stock,but it,s got a few thousand mile on it
Old Jun 27, 2005 | 03:12 PM
arsenal21's Avatar
I cant wait for an ECU to come out for our cars. Then we'll beable to adjust whatever we want to.
Old Jun 27, 2005 | 03:34 PM
MarcS's Avatar
The Stig
Interesting, how did the tubes effect the psi exactly? Did it allow boost full time instead of it being based on engine load?
Old Jun 28, 2005 | 09:05 AM
we were getting boost instantly from the moment you press the gas pedal.
Old Jun 28, 2005 | 09:34 AM
Cam9730's Avatar
Why would GM do something like making the ECU so tightly locked and not release any upgrades for us? They tend to leave their best people out in the cold it seems.
Old Jun 28, 2005 | 12:13 PM
MarcS's Avatar
The Stig
Hmm, did the CEL turn off when you reconnected the lines to where they should be? Also, would you say theres a performance benefit to running full boost all the time?
Hope you don't mind that I keep bugging you about this
Old Jun 28, 2005 | 12:43 PM
MarcS you ask if there's a benifit in running full boost all the time, right?? How can you get full boost all the time??? Boost is related to RPM when you are running a belt driven SC. So adjusting the BPV would only help throttle response (instant boost)
Unless I don't understand this roots style blower fully you'd have to get the rpms in the upper 5000's to get full boost. How I'm understanding the cobalt is that the BPV 'should' close once there is no vacuume (WOT), and then the PCM would then sense manifold presure some how and if it exceeds a pre determined threshold it would then open the BPV to vent the excess pressure. Correct??
Old Jun 28, 2005 | 03:18 PM
MarcS's Avatar
The Stig
Ah, I'm sorry I didn't mean full boost as in 12psi. I meant full boost(instant boost) as in boosting all the time instead of being regulated by the bypass valve. Hence, the SC boosting into the engine "full time" and not into the atmosphere.
No, you're right. Full boost can't be acheived until you're in the upper rpm's. Sorry for the confusion.
Old Jun 30, 2005 | 08:41 PM
phxSS's Avatar
Yes, Camaro, you're right. The BPV closes when you're WOT. The piston in the valve housing closes when there's no vacuum to hold it open, letting "full boost" into the engine.
Old Jul 6, 2005 | 09:09 PM
zinner's Avatar
Moderator Alumni
The actual valve is inside the eaton, but the the actuator is a little black cylinder with vaccum lines and a metal shaft that moves the value.
Old Jul 7, 2005 | 01:31 AM
SilverSS/SC's Avatar
Give it time on the PCM . Like every new model that comes out , it takes a bit to break into . The aftermarket had a hell of a time with the C6 PCM too . Plus GM is wanting a slice of the aftermarket as well , hello GM accesssories ....with what I understand to be performace packages for the SS . There is probably MUCHO to gain though just in tuning the PCM and a better intercooler or something like coolmist , and leaving everything else stock . Given it supercharged , the stock PCM is proabaly tuned WAAAAAAAAAAY on the safe side of things . Good for longevity , not as good for performance . Itll be interesting to see how easy this thing respnds . I havet touched a thing on mine yet , AMAZINGLY
Old Jul 10, 2005 | 04:45 PM
BullDog71ss's Avatar
Along with the tuning that comes along with a new PCM, our SS/SC's could really benifit from having the rev limiter raised from 6600 rpm or so to about 7200 rpm. These engines scream for more revs.
Old Aug 4, 2005 | 01:38 AM
Mercury's Avatar
You think that with GM making a performance car that they wouldn't put that many restrictions on it..... damn ecu
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
