Am I missing a bolt ?
I was going to remove the oil pan tonight and seem to have run into a small problem.
I removed the lower A/C comp mounting bolt, loosened the other two.
I removed the dipstick tube.
I removed the 4 oil pan to trans bolts.
I removed the 15 oil pan bolts.
Did I miss one, seems as though its still stuck and won't come down ?
Maybe I'm tired and need rest, see what happens in the am.
Thanks for any advice at all !
The silicone that gm uses on the pan is good stuff man. i had a heck of a time the first time I had mine off. You gotta find the little spot on the pan you can use a pry bar on. And there is a long bolt that goes straight up, not into the bell housing but right there. Hope this helps
z28addiction
Sep 28, 2015 12:03 AM
