Forced Induction Turbos/Superchargers
Am I missing a bolt ?
Old May 10, 2010 | 01:16 AM
Cherry GT's Avatar
I was going to remove the oil pan tonight and seem to have run into a small problem.
I removed the lower A/C comp mounting bolt, loosened the other two.
I removed the dipstick tube.
I removed the 4 oil pan to trans bolts.
I removed the 15 oil pan bolts.
Did I miss one, seems as though its still stuck and won't come down ?
Maybe I'm tired and need rest, see what happens in the am.
Thanks for any advice at all !
Old May 10, 2010 | 09:36 AM
Cherry GT's Avatar
So many looks........
No one knows ?
I know many people have removed the oil pan.
Thank You
Old May 10, 2010 | 09:00 PM
terry11's Avatar
The silicone that gm uses on the pan is good stuff man. i had a heck of a time the first time I had mine off. You gotta find the little spot on the pan you can use a pry bar on. And there is a long bolt that goes straight up, not into the bell housing but right there. Hope this helps
Old May 13, 2010 | 08:45 PM
Cherry GT's Avatar
Yep all the bolts were out.......
Finally I got brave and whacked it good
it came off then.
Old May 13, 2010 | 10:20 PM
terry11's Avatar
it came off then.
yeah man thats good stuff whatever it is
DarrenGC
Dec 24, 2021 01:55 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
z28addiction
Sep 28, 2015 12:03 AM
