Forced Induction Turbos/Superchargers
Blower condition/grease?
Old Dec 29, 2009 | 09:00 PM
Perfect.disguise's Avatar
Looking at picking up a spare blower from someone. Though I have a question.
He plugged the silencer holes. (used a dremel then alcohol to prep then quiksteel) any ways he said the blades were slightly hitting the plugs so he shaved a tiny bit off.My question is that in the housing there is very fine "scratches" around the plugged area. It's more like a tiny scuffs, you can't feel them and polishing would take care of them, I've seen them. He just changed the oil in it and hasn't had it on a car. It spins fine, no scratching or grinding rotors are fine. My question is: will leaving it like that have any effect on the air or heat? I mean I wouldn't think it would mess the air flow up more than the silencer holes.
Also any one know what kind of grease is used in the rotor bearings?
Please no guessing, only answer if you really know.
Last edited by Perfect.disguise; Dec 29, 2009 at 09:00 PM. Reason: Automerged Doublepost
Old Dec 29, 2009 | 10:00 PM
chevysssc's Avatar
it will only make the sc louder no extra heat iwould only be very worried about the quick steel breaking up over time
Old Dec 29, 2009 | 10:26 PM
I was just worried that the small fine scuffs inside the housing would have had some kind of effect. Like I said though, you can't feel them and the rotors turn smooth with no noise.
I will keep a check on the silencer plugs. They would have to be tiny pieces to make it past the IM.
Old Jan 2, 2010 | 10:20 AM
chevysssc's Avatar
ur fine then
Silverbullet333
Oct 4, 2015 02:27 PM
jimbofug007
Oct 2, 2015 12:06 PM
goaliemo
Sep 28, 2015 01:37 PM
yellowsupercharged06
Sep 17, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
