Forced Induction Turbos/Superchargers
Boost guage readings
Old Jul 9, 2011 | 04:07 PM
Coby The Killer's Avatar
This may be a dumb question but i have never used a boost guage that reads 0-35 mine have always been your normals that show a - number as well. When idleing with a supercharger what should the guage be showing? I am reading 5 psi at idle.
Old Jul 9, 2011 | 04:28 PM
09BlueBaltSS's Avatar
u should be in vac
Old Jul 9, 2011 | 04:31 PM
TommyP's Avatar
AWD > FWD
yep, you should NOT be showing any boost at idle. Could be a bypass valve issue id guess.
Old Jul 9, 2011 | 04:37 PM
any idea were to start to maybe correct this issue. i have it hooked directly into the manifold for pressure, I just never had one that didnt read the -s so i didnt no if it should idle at 0 or show pressure
Old Jul 11, 2011 | 12:53 PM
busa4's Avatar
you have a boost gauge only, correct? if so, check to see if you can calibrate it. i highly doubt you have 5 psi idling. if you turn off the engine what doe sthe gauge do? if you try to go into boost what does the gauge do? what make of gauge is it?
turbochargedss2012
Sep 20, 2023 12:17 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
dennis69
Sep 28, 2015 02:16 PM
