Forced Induction Turbos/Superchargers
BOV Install question
Old Jul 17, 2011 | 02:05 AM
JAYNO20's Avatar
If I put a BOV on my car and replaced the factory BPV with a treadstone block off plate, all I do is run the vacuum hose from the factory BPV location to the BOV, right? The only other step was to put a T fitting in and run vacuum line to the stock BPV, but without it I don't need to worry about that step, right?
Old Jul 17, 2011 | 03:22 AM
iboost's Avatar
That's what I did
Old Jul 18, 2011 | 12:16 PM
busa4's Avatar
just make sure the bov is located before the maf or you can cause an interm rich condition when throttle is closed. in some cases the engine may stall out, flood, foul out plugs, damage catalytic or hydrolock
Old Jul 22, 2011 | 08:00 PM
JAYNO20's Avatar
OK Vince from Trifecta said I should use the line from the intake manifold instead of the line from the stock BOV after having my MAF relocated and blocking off the stock bpv. Can anyone show me where the vacuum line from the intake manifold is?
Old Jul 23, 2011 | 07:22 AM
JAYNO20's Avatar
Anyone?
Old Jul 23, 2011 | 08:47 AM
mkulrey13's Avatar
I ran the vaccum from the stock BPV to the BOV instead. Ran fine. I used a TTR Block off plate and ZZPs lower pipe with MAF relocate. No Issues. I have since returned back to stock BPV but continue to use the ZZP map relocate lower pipe. I was tired of the BOV Flutter. Stock to your stock BPV or go forge BPV. Ours cars do not need a BOV.
Old Jul 23, 2011 | 03:36 PM
JAYNO20's Avatar
Has anyone hooked it up this way before?
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Bohb
Sep 27, 2015 09:11 PM
