Forced Induction Turbos/Superchargers
BOV on stock SS/TC?
Old Oct 13, 2012 | 11:15 PM
turbochargedss2012's Avatar
BOV on stock SS/TC?
i want to put a BOV on my stock 2009 SS/TC. is that even possible ? bc i heard they have what is called a bypass valve that reroutes the air back into the motor. so is there a way you can install a BOV? is it hard ? easy? any help would be great thanks guys
Old Oct 13, 2012 | 11:23 PM
bluebalt07's Avatar
You'd need charge pipes and a block off for the stock bypass valve. Most people are gonna say not to do it on stock turbo because most people have issues with it
Old Oct 14, 2012 | 03:06 AM
Nfamous60's Avatar
^^^ second this few of us have put on BOVs with stock turbo and had minimal issues i for one have installed one on stock turbo, treadtsone block off plat$24 i think your going to need charge piping lots of designs and company's offer so your choice and your choice of bov as well, the bov should come with a flange and it should be fairly cheap to have it welded on like $35-$60 depending where you want it mounted. and good to go, Some will say get a tune for it or a new intake with a maf relocate $200+ maf extension harness $30 and your goin to need new lower charge pipe but you can get a upper n lower set for a good deal, believe theres a set on the classifieds made by hahn for $250 i think thats the piping i have.
this is my setup:
Omiotek's Avatar
yes and no blue bolt... its to me a pointless waste of money. lets just say he uses a tial bov for the cost of 250.00, has to buy pipes for whatever the cost with a flange or have a flange welded to a pipe and do a maf relocation to run it properly the costs add up quite a bit depending on which way you go.
the stock setup works, works good and with a intake you can hear the stock bpv just fine. if you want a good upgrade go with the forge bpv. it needs some maitence but so does any good blow off valve.
a new lower pipe is not always needed either. is it good to replace? sure if your buying a set but its not a 100% neccisity on the stock setup.
Old Oct 15, 2012 | 07:36 PM
thanks guys i think ill just get a hahn cai and roll with that for now.. thanks guys
Old Nov 18, 2012 | 10:43 AM
Silverbullet33's Avatar
ive got the zzp set up with flange and maf relocate + running hks bov and block off plate, no retune yet will do in the spring when shes out for nother season and not even had an issue yet. just my experience tho..
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
