Bypass valve allen adjustment
Hello all , does anyone know how to make sure that the bypass butterly is properly adjusted. My ss/sc seems to be alittle light on boost at around 11psi (@ 500ft above SL) and id like to make sure that the bypass is adjusted right , there seems to be quite alot of adjustment when i back it all the way off ( almost 2 full turns) . Without the rubber touching the stop their seems to be allitle bind in there , but if i bring the adjuster out to where it just touches it goes away . I marked the adjuster with a sharpie so i know where it was from the factory . I figured i better ask before i run it . Thanks .
