Forced Induction Turbos/Superchargers
Devilsown alcohol injections Questions and answers
Old Feb 22, 2008 | 03:57 AM
devilsown's Avatar
Ask your questions here about cobalt ss stage 2
Old Aug 22, 2008 | 11:10 AM
devilsown's Avatar
Had afew people been asking thought i would clarfy. Controller is about 1/2 the size of the picture show. Its one of the smallest on the market. Any other questions about alcohol injection let me know.
Old Aug 25, 2008 | 10:17 PM
devilsown's Avatar
Anyone got any questions don't be afraid to ask.
Old Aug 26, 2008 | 12:24 AM
Tennpenn83's Avatar
How involved is this to install?
How much room does a seperate tank/pump take up?
What kind of wiring do I need to worry about?
Where can I find a good meth/water mix? Does it hurt to use the windshield washer fluid?
Old Aug 26, 2008 | 11:56 AM
devilsown's Avatar
Actually these are really easy to install. Most cobalt installers mount the controller on the dash. Remember our conroller is 1/4 the size of other controllers on the market. Then hook up 4 wires from the controller. Ground, power, signal wire to your map sensor, and power wire to the pump.
Most people mount the pump in there fender area, and they use there stock washer tank. Whats nice about doing it this way is you don't have something taken up space in your trunk. That you always have to fit your stuff around.
The wiring is pretty easy, We supply these http://www.alcohol-injection.com/art...-connectors-3/ with every kit so it really speeds up the install and your don't have to hack up your wiring.
Any of your local race tracks have meth for sale. Usually cheapest to buy it there and then buy distilled water and mix it 50/50. Nope your cheaper washer fluids are perfect for injecting. Most washer fluids are made with just water and methanol.
Old Aug 26, 2008 | 02:32 PM
Tennpenn83's Avatar
Just wondering about the tank, how big is it? Reason being, I have a whole crapload of extra space on the passenger side in the fender well. The cobalts get the ww tank there but on the redlines it's on the driver side. Perfect for a cobalt ww tank or another tank to fit there. (that way i can use the meth in the pass side and the stock ww tank still has the bug remover **** lol)
Does the meth or meth/water mix have any effect on the supercharger? I know it cools it down but does it take any coating off the blades? ANY cons of using meth?
Old Aug 26, 2008 | 02:35 PM
ikeryder13's Avatar
is meth continously ran or like NO2?
Old Aug 26, 2008 | 02:53 PM
devilsown's Avatar
Tennpenn83 We have quite afew tanks we sell seperate to the kit. Don't want to force people into a paticular tank if they don't need it. http://www.alcohol-injection.com/tanks-6/
I will see if i can find the pics i have of an install on a redline.
Its honestly debatable, I still have all the teflon on the rotors on my car. My business partner are 100% clean. Just like i can find a stock car with no feflon. I think it just boils down to the process when it was applyed. Now the water/methanol injection kit will help seal the rotors if the teflon is startting to flake off.
ikeryder13 The methanol/water injection kits only come on when your engine is under boost. This is when your engine is under load and when the most heat is being produced.
Old Aug 26, 2008 | 02:55 PM
ikeryder13's Avatar
Is there a Level of boost that it starts at? I am intrested in this but i wanna know what kind of tune and other cooling parts i would need
Old Aug 26, 2008 | 02:59 PM
devilsown's Avatar
Its acutally adjustable. If you look at the enlarged picture you will see 2 knobs. The knob on the left is the start point knob. You usually adjust this to 1/4 of your max boost. The 2nd knob is where the system runs the pump at full.. You will want to set this knob at aprox. 3/4 of your max boost.
Old Aug 26, 2008 | 03:05 PM
ikeryder13's Avatar
what about the tune? Is one required?
Old Aug 26, 2008 | 03:09 PM
devilsown's Avatar
Sorry missed the 2nd part of the question. Water/methanol injection is a supporting mod for the car. It allows for you to run a more agressive tune, "more boost, more timing, more power" So tunning the car and adding more boost and timing is going to make you the power you want. Just putting it on and not adjusting anything on the car the gains are going to be min.
Old Aug 26, 2008 | 03:11 PM
ikeryder13's Avatar
oh ok... thank you
Old Aug 26, 2008 | 03:17 PM
devilsown's Avatar
Your welcome. Any time you do add anything to a engine that effects air/fuel you will see increased benefits if you tune the car afterward.
Old Aug 26, 2008 | 03:34 PM
black06ss's Avatar
click. just incase i think of any questions.
Old Aug 26, 2008 | 04:40 PM
Area47's Avatar
Rent me! per hour
after a year of spraying meth/windshield washer fluid through my m62 before i pulled it off. i had zero issues with it.
pics of the blower can be seen in my "m62 forsale" thread
Old Aug 26, 2008 | 05:42 PM
Tennpenn83's Avatar
area, does the harrop have teflon coated blades?
Old Aug 26, 2008 | 05:45 PM
lsjwannabe's Avatar
The coating is not teflon....
Old Aug 26, 2008 | 05:55 PM
Tennpenn83's Avatar
elaborate.... lol
reason is, eventually, like around tax return time, i'll be getting my harrop. would like to know all supporting mods i need to get there. i think for the most part i have what i need except the 60's, meth, and exhaust.
and does the harrop have any coating on the blades? what is it made of? on either the eaton or the harrop, what do i have to worry about - will the coating get into the engine?
Old Aug 26, 2008 | 05:57 PM
lsjwannabe's Avatar
It does it uses the same coating as gen 5 blowers, its not public knowledge what it is, and im not at liberty to reveal unless given the ok from the powers that be.
Old Aug 26, 2008 | 06:09 PM
Tennpenn83's Avatar
lol ok...
Old Aug 26, 2008 | 06:11 PM
lsjwannabe's Avatar
you have a pm
Old Aug 26, 2008 | 06:14 PM
Tennpenn83's Avatar
you have a pm
gotcha
on a different note, what iat differences are there between the eaton and the harrop? the harrop obviously flows more air more efficiently but what is the temp difference?
Old Aug 26, 2008 | 06:16 PM
lsjwannabe's Avatar
with more air comes more pressure with more pressure comes more heat. It does the job well but it can still run into heat issues. On the 2.75" and the 5 gph nozzle with a 30/70 mix i was going through the traps at 153 with a iat1 of 100
Old Aug 26, 2008 | 06:19 PM
Tennpenn83's Avatar
2.75" pulley equals how much boost? how much boost can you run before even the 60's aren't enough? you said meth of course, but were you running any dual-pass w/ opt b or additional heat exchanger like i have?
