Forced Induction Turbos/Superchargers
Devilsown alcohol injections Questions and answers
Old Aug 26, 2008 | 06:22 PM
lsjwannabe's Avatar
25 psi, you are past the safety net i like. a 2.9 is as far as i would push it on stock fuel. I ran every cooling mod
Old Aug 26, 2008 | 06:34 PM
Tennpenn83's Avatar
stock fuel meaning pump gas i assume?
what kind of hp you seeing? I'm aiming for a 350-400hp daily driver with some track use
what i currently have :
Stg II injectors/belt
2.8" pulley
NGK BKR7E's gapped at .035"
K&N CAI
LS4 TB
TB spacer plate tapped for meth/nitrous (but currently just plugged as I have neither)
ZZP mid-length header/3" downpipe to 2.5" hi-flow cat to stock cat-back with Magnaflow muffler
dual-pass w/ opt B
CX Racing Dual pass heat exchanger (the small one)
my plans are the following : (keeping all of my current setup except the eaton and 42's)
harrop (of course)
60's
full 3" exhaust
meth
nitrous
and... i'm pretty sure ill need a clutch after this setup (and probably pistons too)
Old Aug 26, 2008 | 06:40 PM
lsjwannabe's Avatar
ie returnless style, i converted to return style. The car did 320whp on the same dyno i did 253 with my 2.5" and meth on the m62
Old Aug 26, 2008 | 06:43 PM
Area47's Avatar
Rent me! per hour
::looks at thread title. looks at posts:::
Tennpenn83's Avatar
i'm only a couple hp off your 253. with all the mods listed except the heat exchanger which i just installed.
what mods did you have other than the 2.5 and meth for the 253?
is the return style fuel system a definite upgrade for the kind of power i'm aiming for?
Old Aug 26, 2008 | 06:54 PM
cobaltR's Avatar
Can u explain the difference between the base kit and the progressive kit.
Old Aug 26, 2008 | 06:58 PM
Tennpenn83's Avatar
hey now at least i started off asking about meth.
and i was the only one to do so for a while
Old Aug 27, 2008 | 09:20 AM
black06ss's Avatar
the base kit kicks on as soon as the specified boost is made with the progressive it starts and at Xpsi and works up to 100% at Xpsi
Old Aug 27, 2008 | 10:35 AM
lsjwannabe's Avatar
every mod i had when i dyno'd the harrop besides the intake and return style. My dyno is a heart breaker.
Old Aug 28, 2008 | 11:54 AM
devilsown's Avatar
cobaltR
Our DevilsOwn Stage 1 "Base" injection kit incorporates a boost switch that activates the system at a specific PSI. It’s adjustable from 2-10 psi or 6-30psi, but you can run up to 250 PSI through the switch, so it’s very reliable. This system will turn on at a level you set and stay on until you drop below that level. It’s On/Off. It can’t dial in exact flow, but it can get you within a range.
DevilsOwn Stage 2 "Progressive" kits offer high functionality and performance, the ability to vary the flow based on inputs (maf, map, tps, ait, any 0-5v source). Most users run it off of separate GM style map sensor if there car does not already have a map sensor. With the Stage 2 Kit you set a starting boost and a full boost and the system will progressively adjust the flow between those two points.
Both styles work. We tell our customers that if budget is the primary concern, get the base injection kit. If you have a little more money to spend or want something with more user control, the progressive kit is worth it.
Old Sep 8, 2008 | 01:26 PM
  #36
devilsown's Avatar
Any other questions i can help with?
Old Sep 8, 2008 | 01:41 PM
  #37
blazinbaltss's Avatar
can u make homemade juice from winsheild washer fluid?
Old Sep 8, 2008 | 03:17 PM
  #38
Billig ss/sc's Avatar
Do you guys have a "how-to" for the install on your site or on here anywhere? Mine should arrive by time I'm home from vacation. (cant wait)
Old Sep 10, 2008 | 02:04 PM
  #39
bump?
Old Sep 10, 2008 | 02:33 PM
  #40
ebristol's Avatar
Here is where I mounted mine on a Redline:
The install is very easy.
I stuck my controller in a spare compartment to the left of the steering wheel in the Redline. Tapped the fuse panel inside the car for power and and ground. Ran the wire for the pump and Map sensor through the gromet on the drivers side. I have not installed the injection nossel because I am waiting for a TB spacer that should be here any day.
Old Sep 10, 2008 | 03:06 PM
  #41
Old Sep 10, 2008 | 03:08 PM
  #42
Kibosh3's Avatar
yes..the blue stuff without "de-icer" and some heet....
but why do that, just find a place that sells pure methanol and mix ur own....took me a while, but i found a place...
Old Sep 10, 2008 | 08:22 PM
  #43
Well if I had an Ion that'd work haha. That's where our intake is so that's kinda out. Good hiding place though
Old Sep 15, 2008 | 03:14 PM
  #44
devilsown's Avatar
blazinbaltss
You can make your own Brew by using 49% methanol and 51% distailled water.
Thats a nice install. Copyed your images for when someone else wants to see what they look like installed.
Old Sep 15, 2008 | 03:17 PM
  #45
Originally Posted by devilsown
blazinbaltss
well i just bought your kit but i mean whats the best thing to do make your own up like you just said or to just buy pure methanol from somewhere and if so where is the cheapest place to get it
Old Sep 15, 2008 | 03:33 PM
  #46
devilsown's Avatar
Lots of places you can buy methanol at. Just have to call around to some race shops that are local. Or even look for who supplys the race shops, most places will sell to anyone with a empty fuel jug.
Old Sep 25, 2008 | 02:24 AM
  #47
M88ArRamadi's Avatar
A while ago I bought the snow performance kit....not much of a fan for their controller, garbage actually....question is:
Can I replace the snow performance controller with yours? if so how much?
Old Sep 26, 2008 | 12:00 PM
  #48
devilsown's Avatar
Yea, our controller can easly be swaped out. Your going to want our 2.5 bar controller and its 145.00
Old Oct 16, 2008 | 10:16 PM
  #49
Josh@ottp's Avatar
Anyone else have questions?
Old Oct 17, 2008 | 10:41 PM
  #50
qwikredline's Avatar
yeah what time is it? he he awesome info i love my OTTP throttle spacer
