Downpipe options for turbocharging
i was looking around and i was trying to figure out what my options for downpipes are....i was reading a thread somewhere and i saw something about vbands....for a downpipe....how do they work?....whats my best route to take as far as downpipes goes?
ok a turbo specific downpipe is typically shorter and set llower than stock and has either a 4 bolt or 5 bolt turbine outlet hookup...generally theres abut a 90 degree bend right at the outlet...which in our cars makes for a hell of a difference and requires a custom downpipe to be made
I"ll take pics of both of mine when I get home to show you the difference. And v-band styles work pretty good, easy to put on and take off. Just basically 2 round flanges with a lip and a clamp with a u shaped groove in the middle to clamp both together. I ended up going a custom route, actually through cobalt-addiction. Took Kenny about 20-30 minutes to tack it up, and Matt finished welded it in a few minutes after that. I'm running a 5-bolt flange style on mine, little bit harder to make the dp for that becuase all the bends must be exact and the angle must be perfect, v-band you get a little rotational play to help ya out.
it's not that it wouldn't work with forced induction. when you have a turbo, you now have a turbo manifold that needs to bolt to the downpipe. so your downpipe has to match the flange on the manifold. which is why most people go custom.
thats a custom downpipe that was made...just included witht the kit for mass production....and its specific to that turbo...would not work for me
