Forced Induction Turbos/Superchargers
Downpipe options for turbocharging
Old Sep 3, 2007 | 12:26 PM
mike25's Avatar
i was looking around and i was trying to figure out what my options for downpipes are....i was reading a thread somewhere and i saw something about vbands....for a downpipe....how do they work?....whats my best route to take as far as downpipes goes?
Old Sep 8, 2007 | 12:35 AM
kovich14's Avatar
cobalt-addiction makes 2.25" and 2.5" either with or without cat; i believe they use vibrant cats. hahn racecraft also makes a down pipe. i believe it is 2.75" w/ cat
Old Sep 16, 2007 | 07:32 PM
mike25's Avatar
those arent for turbocharging...i need a turbo specific downpipe
Old Sep 18, 2007 | 06:54 PM
Maxim_X's Avatar
I think the consensus is everyone here making going turbo is going to a good exhaust shop and getting a custom piece or making their own.
Old Sep 18, 2007 | 06:57 PM
D4u2s0t's Avatar
custom.
Old Sep 29, 2007 | 03:06 AM
kovich14's Avatar
okay. explain to me the difference in a "turbo specific" downpipe as you call it, and a regular downpipe.
Old Sep 29, 2007 | 09:02 AM
mike25's Avatar
ok a turbo specific downpipe is typically shorter and set llower than stock and has either a 4 bolt or 5 bolt turbine outlet hookup...generally theres abut a 90 degree bend right at the outlet...which in our cars makes for a hell of a difference and requires a custom downpipe to be made
Old Sep 29, 2007 | 09:23 AM
06blackg85ss's Avatar
I"ll take pics of both of mine when I get home to show you the difference. And v-band styles work pretty good, easy to put on and take off. Just basically 2 round flanges with a lip and a clamp with a u shaped groove in the middle to clamp both together. I ended up going a custom route, actually through cobalt-addiction. Took Kenny about 20-30 minutes to tack it up, and Matt finished welded it in a few minutes after that. I'm running a 5-bolt flange style on mine, little bit harder to make the dp for that becuase all the bends must be exact and the angle must be perfect, v-band you get a little rotational play to help ya out.
Old Oct 2, 2007 | 05:23 PM
kovich14's Avatar
okay...still not understanding why an adequately sized down pipe with a hi flow cat wouldnt work with forced induction.
Old Oct 2, 2007 | 06:14 PM
D4u2s0t's Avatar
it's not that it wouldn't work with forced induction. when you have a turbo, you now have a turbo manifold that needs to bolt to the downpipe. so your downpipe has to match the flange on the manifold. which is why most people go custom.
Old Oct 3, 2007 | 08:54 AM
kovich14's Avatar
ok, got ya. if one buys a turbo mani that bolts up to the stock downpipe, then this is not needed; any stock replacement will do.
Old Oct 3, 2007 | 08:14 PM
mike25's Avatar
not sure what your saying...turbo downpipe requires a special 4 or 5 bolt flange
Old Oct 5, 2007 | 02:38 PM
Jmc007's Avatar
There isn't any turbo manifold that will fit the stock DP.
Old Oct 6, 2007 | 01:23 AM
kovich14's Avatar
the manifold in the hahn system for the 2.4 and the garrett system for the 2.2 hook to the stock exhaust. the picture of the system clearly shows a three bolt flange.
Old Oct 6, 2007 | 08:40 PM
mike25's Avatar
thats a custom downpipe that was made...just included witht the kit for mass production....and its specific to that turbo...would not work for me
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
