Edubs Turbo Build Complete! NO*56*NO
#128
...as do you!
#132
Eh, between working full time, two grad classes and a bunch of other **** going on...I really just haven't had time to do much with this. Not to mention, the sleeves still won't be ready for another week at the least...
Still coming apart, actually. I still have to have the machine shop tear down the block and ship it to Darton. Hopefully things will start to move faster once Darton has the block.
#133
nope was a serious question. did you test the flow on it? are you getting equal flow in the runners? any sort of heat soaking in the manifold itself? what type of gaskets were used for the installation of the throttle body to manifold itself??? just some things to consider.
#134
#137
OOOMMGG that looks sooo sexy
i kinda like that intake mani a lil too much i think its time to get one
#141
Such a nice clean turbo set up Next winter Im going to redo my charge piping..gotta keep up with the jones's. 06 when you say the gate placement I'm assuming you mean the wastegate placement on the turbo mani...why is it the worst place possible? it seems fairly common on alot of tubular equal lengths to be located there? Should it be at the top?
#143
Edubs: Your piping is all 2.5" other than a small section of 3" where the MAF is located right? and then it goes back to 2.5" then to the throttle body? I was under the impression that once u went to 3" for the maf section you should carry that sizing all the way to the TB?
#145
#147
k i read it thx. could u get me a few close up detailed pics on the intake? where all the stuff is if u dont mind. also im internal so i would have to plug that connection until i was to go external correct?
#150
The turbo manifold can easily be made w/o the external flange, but if you want to eventually upgrade turbos, you can buy one like mine. What turbo are you running? This manifold was actually designed around our special built T3/T4 hybrid, but works w/ the GT3071. We would need to test fitment for any other turbo...
