Edubs Turbo Build Complete! NO*56*NO
#177
He actually did it twice for me. First time he noticed small air bubbles in the base layer so he said he'd do it over again cause he wanted it perfect. Should still have the measurements and everything for it.
Thanks. No clue.
Technically, it was supposed to be done and running in Feb, so I'm not making any promises now. Still have to wait for fabrication on the new intake manifold too. The original one in this thread has the 4" plenum, which is all well and good for up to 400whp'ish. Since I'm going bigger, he's fabricating a 6" plenum race version once the motor is in...
Thanks. No clue.
#178
Thanks. No clue.
Thanks. No clue.
#183
There will be a new thread when everything is said and done, I'll update this one w/ a link when the time comes.
Can't remember, but it wasn't terrible. It's always gonna cost more than a typical one-off vinyl sticker when it has the liquid dome overlay. Just, fyi...
I'll end up painting it black cause it'll kill me to watch that pretty silver get covered in oil, grease and dirt over the first couple weeks after it goes in...
#188
The motor is not even in the car, as you can see from the updated pictures...
It's going to be street tuned, fyi. Dyno may come eventually, but isn't really a concern of mine. Essentially, it'll make what a 3071 makes at about 22-23psi on a well tuned motor...
#190
I am aware the traction will be an issue. I'll prob end up throwing some cheater slicks up front and saving those tires to replace the back ones when they need it. I've been doing my research on DR's while the car has been down...
#192
How much did you end up scoring the BFG's for?
#193
$157 a piece mounted and balanced from Cheney Tire. He matched and beat discount tire's price.
I'm only saying because I tried when the car was at SMG and I ended up just taking the manifold off. I'm going to try again this time and see what happens.
#194
Worst case scenario, you'll have to split the cap from the filter after you lift it up a few inches. I know I was concerned about it from the get-go too but Ryan and I tested it and you just have to angle it a bit as you lift up. You gotta remember that the filter is not as wide as the cap, so you get more clearance once you get passed the the cap threading...
#196
Should be similar to this I would hope. Not sure who's car it is, but looks impressive.
http://www.youtube.com/watch?v=TMvVvfvbDd4
#197
I don't mean to raise the dead, but how is that RD fabs intake manifold working out for you? Any issues with it? I'm looking at purchasing it. Also, I noticed in the photos that I didn't see bungs for the MAP sensor and the supercharger pressure sensor? Does it come with all that goodstuff.
#198
