Forced Induction Turbos/Superchargers
Hotside charge pipe under motor
Old Jul 26, 2011 | 08:23 AM
jonnymerk's Avatar
Can someone post some good pics of the hot-side pipe with the under motor config please.
I'd like to see how it bends and the clearances under neath. I'm considering re-doing my hot-side to get slightly better fitment and reduce the diameter cus my hot-side is 3 inch as opposed to everyone's 2.5inch.
I'm wondering if it might help reduce a tiny bit of turbo lag as well as make room for an intake set up which I lack and don't have room for anyway.
Old Jul 26, 2011 | 11:47 PM
jonnymerk's Avatar
I'm sad no one replies to my threads here or gmsport.net
Old Jul 26, 2011 | 11:55 PM
Dart_SI's Avatar
nobody i know of has a hotside that goes under the motor and nobody makes one either. the turbo outlet is facing directly up, so the easiest route is over the engine unless you get a diffrent turbo with the outlet facing down.
as far as stock goes i think over the engine is the most direct route. specifically the injen upper charge pipe.
Old Jul 27, 2011 | 10:25 AM
jonnymerk's Avatar
Are you sure about that. I recall seeing kits that had the chare pipe run under the motor and I know I see engine bay pics of turbo lsj's that dont have the large section of pipe going over the motor. Maybe I used the wrong term? I'm talking bout the pipe that runs from the turbo to the intercooler.
I wanted pics for the very resaon you stated it seemed like a a bad idea, unless like u said it's only practical with a different turbo config cus my outlet does face up.
Old Jul 27, 2011 | 10:43 AM
BIG SS TC's Avatar
BYT did a custom piping on Donkey's balt that was all under it
Old Jul 27, 2011 | 03:40 PM
jmarks's Avatar
Thats all I have of my set up that I made. It was pretty easy
Old Jul 27, 2011 | 04:14 PM
jonnymerk's Avatar
thanks, I'm thinking based on my set up I may not want to change cus it may cause flow constraints. I might go 2.5 inches and have it adjusted for better fitment and available room to put an intake cus as it stands now there is no room.
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
nathan112i
Sep 30, 2015 07:12 PM
