how many psi does .1 bar equal
i used to know..but i cant remeber..does anyone know? im trying to figure out what bar spring i need for a wastgate
and also does anyone know if the tial 50mm comes with an adjustable spring?
im trying to figure out what spring rate i need for the bov....i want to run about 9-10 psi...question is do i have to have the bov and wastegate set to the same spring rate? i.e with 10psi springs?
The blow off valve isn't rated to how much pressure you're making. It opens when you drop air pressure from releasing throttle.
What? Pressure in the system increases when you close the throttle... when your on the throttle the turbo is flowing air through the charge pipes into the motor. When you shut the throttle by letting off the gas pedal, the pressure builds in the system since the turbo is still making boost, the BOV opens to bleed the pressure to a set PSI.
1 atm doesn't equal 1 bar
1 atm = the pressure at STP (0*C temp @ sea level... literally an atmosphere based unit)
1 atm = 14.6959 psi
(so, yes 1 atm = ~14.7psi)
1 bar = 0.9869 atmoshperes
1 bar = 100 kpa
1 bar = 1N/m2 (the newton was developed as a mass-gravity unit)
Therefore;
1 bar = 14.5038 psi
Oh jeezuz....
1 atm = 14.6959 psi
1 bar = 100 kpa
Therefore;
1 bar = 14.5038 psi
1 atm = 14.6959 psi
1 bar = 100 kpa
Therefore;
1 bar = 14.5038 psi
oh ok i see now...so the BOV goes on the exhaust manifold and the turbo goes infront of the engine and the wastgate goes on the charger piping and gets hooked up to the fuelrail?
This is the best I can do....
Exhaust system
Exhaust manifold -> turbocharger -> turbo back
Therefore -> Waste gate port (on exhasut manifold) -> wastegate -> turbo back
The wastegate goes on the proper port on the manifold, and bypasses exhaust around the turbo.
Intake System
Intake -> turbo -> piping with BOV -> Throttle body -> intake manifold
The BOV will prevent damage to the turbo and/or thottle by access pressure in the system.
It can either dump to atmosphere, or back infront of the turbo (recirculating)
This system does not connect to the fuel rail...
Edit:
Ok... diagram time...
Note: in this diagram, the recirculating BOV is noted as a throttle bypass valve.
Doesn't anyone here check google conversion or online convertion before posting values?
http://www.onlineconversion.com/pressure.htm
What bars do you guys go to? I go to lazy's in hackensack and they serve a mean soco and lime....(yeah i think it's getting a little late for me)....letsj us tsay 1 bar = 14.5-14.7 or say 14.6 since it's in the middle (however i've always went with 1 atm 14.7)
