Forced Induction Turbos/Superchargers
how many psi does .1 bar equal
Old Dec 12, 2007 | 07:43 PM
mike25's Avatar
i used to know..but i cant remeber..does anyone know? im trying to figure out what bar spring i need for a wastgate
and also does anyone know if the tial 50mm comes with an adjustable spring?
Old Dec 12, 2007 | 07:44 PM
DTM2188's Avatar
1 bar is ~15 psi
Old Dec 12, 2007 | 07:46 PM
silverSS's Avatar
~14.5-.7
Old Dec 12, 2007 | 08:14 PM
HunterKiller89's Avatar
1 bar? or .1 bar?
14.7psi or 1.47 psi....
Old Dec 12, 2007 | 08:31 PM
mike25's Avatar
im trying to figure out what spring rate i need for the bov....i want to run about 9-10 psi...question is do i have to have the bov and wastegate set to the same spring rate? i.e with 10psi springs?
Old Dec 12, 2007 | 08:38 PM
NJHK's Avatar
The blow off valve isn't rated to how much pressure you're making. It opens when you drop air pressure from releasing throttle.
Old Dec 12, 2007 | 08:56 PM
mike25's Avatar
o ok..so the wastegate keeps the turbo from creating too much psi?
Old Dec 12, 2007 | 08:59 PM
spaz's Avatar
^yes and the spring is rated at the bypass pressure.
Old Dec 12, 2007 | 09:11 PM
NJHK's Avatar
You mean Manifold Absolute Pressure.
Old Dec 12, 2007 | 09:17 PM
Omega_5's Avatar
1 Bar = 14.5038 psi = 100kpa
As an FYI, the bar system is derived from the metric system.... but not used as part of standard SI units.
Old Dec 12, 2007 | 09:23 PM
Super_SS's Avatar
1 bar=14.57psi
Old Dec 13, 2007 | 12:12 PM
Julex's Avatar
ohh boy, you sure you should be turboing your cobalt LOL, I'd hate for you to put the BOV on the Exhaust mani and Wastegate on the piping. I guess just incase you didn't know what a turbo setup looks like, heres mine
Old Dec 13, 2007 | 12:25 PM
Omega_5's Avatar
Originally Posted by Super_SS
1 bar=14.57psi
... check again...
Old Dec 13, 2007 | 02:52 PM
Julex's Avatar
yea 1 bar is 14.7, because 1 bar is actually considered 1 Atmosphere, WHICH atmosphere is about 14.7
Old Dec 13, 2007 | 03:29 PM
BlackBalt's Avatar
What? Pressure in the system increases when you close the throttle... when your on the throttle the turbo is flowing air through the charge pipes into the motor. When you shut the throttle by letting off the gas pedal, the pressure builds in the system since the turbo is still making boost, the BOV opens to bleed the pressure to a set PSI.
Old Dec 13, 2007 | 03:49 PM
Sw4y1313's Avatar
Incorrect. The BOV Opens when the engine sees vacuum because you attach the BOV to the manifold via a vacuum line. When the throttle closes, the car goes into vacuum and the bov opens letting the pressure currently in the charge piping out.
Old Dec 13, 2007 | 04:03 PM
Omega_5's Avatar
Oh jeezuz....
1 atm doesn't equal 1 bar
1 atm = the pressure at STP (0*C temp @ sea level... literally an atmosphere based unit)
1 atm = 14.6959 psi
(so, yes 1 atm = ~14.7psi)
1 bar = 0.9869 atmoshperes
1 bar = 100 kpa
1 bar = 1N/m2 (the newton was developed as a mass-gravity unit)
Therefore;
1 bar = 14.5038 psi
Old Dec 13, 2007 | 04:13 PM
light'bolt's Avatar
Originally Posted by Omega_5
Oh jeezuz....
1 atm = 14.6959 psi
1 bar = 100 kpa
Therefore;
1 bar = 14.5038 psi
cool..............
Old Dec 13, 2007 | 09:45 PM
mike25's Avatar
oh ok i see now...so the BOV goes on the exhaust manifold and the turbo goes infront of the engine and the wastgate goes on the charger piping and gets hooked up to the fuelrail?
Old Dec 14, 2007 | 12:53 AM
Omega_5's Avatar
This is the best I can do....
Exhaust system
Exhaust manifold -> turbocharger -> turbo back
Therefore -> Waste gate port (on exhasut manifold) -> wastegate -> turbo back
The wastegate goes on the proper port on the manifold, and bypasses exhaust around the turbo.
Intake System
Intake -> turbo -> piping with BOV -> Throttle body -> intake manifold
The BOV will prevent damage to the turbo and/or thottle by access pressure in the system.
It can either dump to atmosphere, or back infront of the turbo (recirculating)
This system does not connect to the fuel rail...
Edit:
Ok... diagram time...
Note: in this diagram, the recirculating BOV is noted as a throttle bypass valve.
Old Dec 14, 2007 | 01:09 AM
Raven SS's Avatar
1 bar is technically 0 because under a bar is vacuum...but yea they are correct 14.7 but that would be 2 bar..
Old Dec 14, 2007 | 01:15 AM
Omega_5's Avatar
... actually, a bar is a gauge reading, not absolute...
Doesn't anyone here check google conversion or online convertion before posting values?
http://www.onlineconversion.com/pressure.htm
Old Dec 14, 2007 | 01:17 AM
memphisr24's Avatar
What bars do you guys go to? I go to lazy's in hackensack and they serve a mean soco and lime....(yeah i think it's getting a little late for me)....letsj us tsay 1 bar = 14.5-14.7 or say 14.6 since it's in the middle (however i've always went with 1 atm 14.7)
Raven SS's Avatar
toemato tomato
Old Dec 14, 2007 | 01:20 AM
Omega_5's Avatar
Boost bar
