Forced Induction Turbos/Superchargers
How much boost on stock lnf
Old Nov 26, 2013 | 02:50 AM
V8THIS's Avatar
Hey guys how much boost are guys running on the stock valve springs? I have mine at 30 and i think im floating valves full boost at higher rpm.
Old Nov 26, 2013 | 03:25 AM
GoodLuckBro's Avatar
In for some info.
Old Nov 26, 2013 | 03:46 AM
thedubsack85's Avatar
on an all stock car with stock turbo it varies... It's Tq on demand and set to make that set number if it takes 15-20+ psi to get there and nothing more! ( ive seen as low as 15 and as high as 23 atleast All stock depending on altitude) All stock motor and turbo with even just a set tune to run 30 LBS is to much and will cause problems with maxing out the turbo. 30 Psi aint to much on the stock block and head depending on it's delivery if running after market turbo! Smooth delivery is key!
Old Nov 26, 2013 | 04:05 AM
V8THIS's Avatar
Well my turbo is not stock, and ive seen it make upwards of 60psi. So what im trying to find out is much is too much for the valve springs. I think its about 28 to 29 because if i turn it down just a little it runs great.
Old Nov 26, 2013 | 10:19 AM
slapbetcommissioner's Avatar
60psi????
Old Nov 26, 2013 | 10:21 AM
nobody2u's Avatar
I think the general consensus is that 22-23 is considered safe.
Old Nov 26, 2013 | 10:28 AM
AaronJ's Avatar
I think everyone in this thread is confused. On the stock turbo, yes 24 psi is the highest you want to go because the K04 is so far out of it's efficiency range that all its doing is making heat and destroying ringlands. V8THIS is on a much larger turbo. I always though valve float was more of an rpm issue than a boost issue. How high are you revving?
Old Nov 26, 2013 | 10:30 AM
umrdyldo's Avatar
I sure hope you typed 60 instead of 30
Old Nov 26, 2013 | 10:33 AM
nobody2u's Avatar
Ohhhhhhh. In my defense he wasn't very clear
Old Nov 26, 2013 | 12:30 PM
Steviodaddio's Avatar
The K04 can make mean torque at 28-30 psi. Nathan with the current car of the month is running 27 or 28 if I remember correctly and his old one was on 29 or 30 for thousands of miles. He's making 324 hp 421 tq with the stock K04. I had always thought it was super inefficient over 24 but from a torque stand point you gain a nice amount cranking it up. Him and a few other guys had no problem proving me wrong when I started that argument.
That's besides the point though.
Isn't the recommended limit 68-7000 on stock springs until you start having issues with float?
Old Nov 26, 2013 | 01:19 PM
V8THIS's Avatar
i dont rev above 6400 i have not changed the rev limiter from stock, and the 60 psi was true, the vacuum line for the boost controller fell of the turbo and the wastegate never opened, the digital gauge went to 60 and stopped, it happened so fast it was rediculous! didnt break anything tho.
Old Nov 29, 2013 | 03:17 PM
Ive seen stock motors on turbo swaps do 30 PSI no problem.. Dart for example with his setup! There are plenty of turbo swaps in the 25-30 range and safe! Just depends on delivery!
Old Nov 29, 2013 | 03:52 PM
Wert842's Avatar
Different turbo, different scenario.
There is no way the stock turbo is spooled to 60psi.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Nov 29, 2013 | 05:22 PM
DarkChild's Avatar
As much as you want. Do it now!
Old Dec 3, 2013 | 12:44 PM
He said he doesn't have a stock turbo.. 4th post on the page.
Old Dec 3, 2013 | 11:18 PM
V8THIS's Avatar
not stock turbo!!!!
Old Dec 3, 2013 | 11:33 PM
colodude18's Avatar
I've always run a 26psi tune. Full E85 on the stock turbo, making 359whp/418wtq (dynojet). Daily driven for 2 years, with many road track days, stock internals just basic boltons. Then upgraded to the ZFR, running E47 @26psi. Didn't get to dyno since my trans expired on the very first track day
BTW I like your screen name Do you have the matching plates?
Old Dec 3, 2013 | 11:40 PM
V8THIS's Avatar
of course i do!
Old Dec 4, 2013 | 12:05 AM
colodude18's Avatar
of course i do!
Nice!!
And I see you're in the Navy; thanks for serving sir!
Turbo Johnny
Feb 21, 2019 09:41 AM
bigdeertz
Nov 17, 2016 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Sep 27, 2015 08:53 PM
