Jn2's m62 build
Jn2's m62 build
well guys after shwong the list of things i need to some people, this seems more duable than the turbo kit, and seeing how i already have the expensive **** as it is...wont cost much to continue, maybe a nother 1000-1500...so i will start working on installing this thing on my 2.2, i know the turbo build went pretty damn good, but in the end i just didnt wanna do it, but not i look at the blower and say ur easier to do...so yeah, i am using becks how to to get this done, so far i havent done any research in the field, so i will do all that tonight, will keep updated when i get more info, so far i have only looked for the intercooler pump, would this one work?
http://cgi.ebay.com/ebaymotors/_Car-...m310061134228&
also if you know wherei can get a 2.5 map sensor please let me know, same goes for the intake manifold mount and the custom idler pulley...b/c i tried going to rebelautoworx.com nothin came up, the si te dont exist no more, unless you have a link for me, i am on my way to workt o get all the lines bolts, drill buts, etc needed...
10ft. x ¾” I.D. Hose
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
Small and Large Hose clamps.
3 x 1/8th NPT ¼” Barb Fittings
Self Tapping Sheet Metal Screws (Mounting H/E brackets)
6M 25mm Bolts
6M 90mm Studs with Locking Nuts
8M 50mm Bolts
Water Wetter Coolant
1/8th NPT Drill Tap
21/64th Drill bit (for the 1/8th tap)
20 gauge wiring
Zip Ties
Electrical Tape
Plastic Wiring Sleeves
also i will be using the CX racing heat exchanger
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
6M 25mm Bolts
8M 50mm Bolts
1/8th NPT Drill Tap
20 gauge wiring
Zip Ties
Electrical Tape
