Forced Induction Turbos/Superchargers
KPA Boost - 93 KPA STOCK!
Old Aug 25, 2006 | 03:44 PM
boostbalt's Avatar
Wow, seems I'm running higher then stock boost right now, I'm putting out at least 90 KPA, I can't look at the boost gauge when I'm going over that amount cause obviously I'm friggen rocketing. But anyway, when I start my car the gauge is not 0'd out, it sits at 3 KPA, and I know I'm getting up to at least 93 KPA meaning my car is running over 13 PSI stock. I'm pretty happy about this, I have one of the last '06's built, perhaps I got a monster.
Ryan
Old Aug 25, 2006 | 03:48 PM
1stbluSS's Avatar
No you have something wrong with your car
1. The cat is clogged causing backup which will make you boost higher
2. Your mani is clogged , same deal
3. Your guage is wrong
I wold take it to the dealer a.s.a.p or you are going to notice a cherry red manifold and cat really soon.
Old Aug 25, 2006 | 03:51 PM
plyboy-illest's Avatar
sounds like a clogged cat...
Old Aug 25, 2006 | 03:52 PM
BLKSS's Avatar
I dont think thats a good sign. I was hitting 85kpa maxed out and idleling -40 -70
Old Aug 25, 2006 | 06:05 PM
p7x's Avatar
p7x
I hit 91 KPA stock, even thats a lil high but cat is most likely the problem.
Old Aug 25, 2006 | 11:14 PM
boostbalt's Avatar
How the hell can it be a clogged cat with only 2900 km on it? What are the signs of a clogged cat? I dont think I have any problems with the exhaust, no smells, nothing...
Ryan
Old Aug 25, 2006 | 11:16 PM
CobaltBurst's Avatar
signs of the clogged cat are abnormal boost lvls.... and it happens to alot of the cars with low mileage...
Old Aug 25, 2006 | 11:29 PM
trollwhite's Avatar
mine did the same thing with only 3500 on it. i was boostin high and bout a week later my cel light came on. took it in and had a clogged cat. the replaced it under warrenty
Old Aug 25, 2006 | 11:42 PM
boostbalt's Avatar
Im going to run it until a CEL is thrown, cause right now nothing appears to be wrong... Will a clogged cat definately cause a CEL? I am going to get under the car next time I run it hard and look for a red cherry.
RYan
Old Aug 28, 2006 | 04:48 PM
Dezod's Avatar
93 KPA ~ 13.48 PSI as an FYI
Old Sep 17, 2006 | 11:20 AM
FraGmE's Avatar
mine runs around 89kpa above 5500rpm or so (seems to be about 12.9psi). I'll check it again today.
KPA TO PSI CONVERSION
Old Sep 17, 2006 | 11:23 AM
kissmySS's Avatar
when the air is good mine WILL hit around 90KPA as well my cat has been checked its fine so who knows...!
Old Feb 18, 2019 | 11:26 PM
cobalt ss/sc2006's Avatar
100 kpa stock
I hit 100 kpa "stock" at Idle my gauge read -60 kpa and at 5500 rpm i read 100 kpa and i havé the 3,35" pulley!
Old Feb 19, 2019 | 12:03 PM
ProfDNS's Avatar
Another ID 10 T reviving a 13 year old thread.
Remyred07
Feb 8, 2012 12:40 AM
Boostin'
Forced Induction
Oct 20, 2010 04:53 PM
Mrterry1
Oct 9, 2010 11:51 AM
06YellowSS/SCinSC
Oct 28, 2008 07:21 PM
Bhill0317
Sep 2, 2007 02:48 PM
