Forced Induction Turbos/Superchargers
M62 silencer ports?
Old Oct 6, 2010 | 03:02 PM
1LowLS's Avatar
M62 silencer ports?
Could I TIG weld sheet metal plugs over the silencer ports?Or would it be too risky in warping the case?
Old Oct 6, 2010 | 03:07 PM
hawlyns711's Avatar
tig would be alright if you have somebody who know's what they're doing and properly grounding before welding at the min. power level. 100% risky.
aren't the holes providing extra airflow too?
Old Oct 6, 2010 | 03:11 PM
1LowLS's Avatar
not sure.I thought eaton said there were for silencing purposes only.My buddy would weld it not me.I cant TIG at all hha.but hes extremely good at it
Old Oct 6, 2010 | 03:13 PM
Bl4des's Avatar
i wouldn't do it
it might warp
Old Oct 6, 2010 | 03:14 PM
hawlyns711's Avatar
your buddy would be the one to ask, if he really knows what he's doing he can answer that question. but if he can't I'd look elsewhere. I'm sure it's possible, have you considered the quick steel stuff I've seen people drill dimple holes around the holes you're trying to plug just so more steel stuff adheres to the s/c making it less likely to fall out. roughing up the surrounding surface isn't a bad idea either
Old Oct 6, 2010 | 03:21 PM
1LowLS's Avatar
meh i dont trust that stuff.ill probably just leave them
Old Oct 6, 2010 | 06:25 PM
Snakes709's Avatar
why do people do this? if you want it just for the whine of the supercharger then i suggest getting a microphone and sticking it near the supercharger or record the sound and play it on the speakers. You are risking the the supercharger and engine just for a small increase of sound....
Old Oct 6, 2010 | 07:25 PM
HyperMuffin's Avatar
If you did quick steel it, and somehow it did break off, wouldn't the chunks of quick steel get caught in the laminova cores before it actually got into the engine? Assuming it is a decent sized chunk of metal.
Old Oct 6, 2010 | 07:28 PM
denlou's Avatar
You're assuming the cores will stop the gobs of quicksteel before destroying at minimum the blower, if not causing some nasty backfire on the motor.
The inside of the supercharger case is precision machined to fit the rotors, I don't know why you would want to go **** with that over a $5 jar of quick steel.
But hey, they put 4" pipes on 1.3L Hondas, so I guess it wouldn't be unheard of.
Old Oct 6, 2010 | 07:35 PM
Jaredssbalt's Avatar
I used quicksteel and did it when I painted mine and to be honest it's not that noticeable of a difference. You hear the whine a little sooner but I don't really think it's any louder. But quicksteel does work I've had mine on for almost 10k miles and have checked it 3 times and everything it just how I left it.
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
