Forced Induction Turbos/Superchargers
Noob To superchargers
Old Feb 13, 2014 | 12:22 AM
sheape's Avatar
Question Noob To superchargers
I know i can adjust boost with changing my pulley size, but on the ZZP Eaton M62 theres a waste gate can i change boost with this? is there a electronic boost controller or a way to adjust boost besides changing pullys and tune?
Old Feb 13, 2014 | 12:27 AM
andrewcarr1993's Avatar
Pulley and tune, but technically a ported head, better exhaust and cams will all lower the PSI while increasing power. PSI is a measure of the restriction so lowering the restriction lowers the PSI while increasing power.
Old Feb 13, 2014 | 07:24 AM
Staged07SS's Avatar
Administrator
Administrator
On roots type blower, boost is altered by pulley ratio, or flow.
A reduction in restriction will lower boost ie. exhaust, ported head, etc.
You can not tune in the amount of boost like on a turbo car.
There is no "waste gate" on the M62 blowers. That is a boost bypass actuator.
Old Feb 13, 2014 | 06:49 PM
sheape's Avatar
Thank you for the replies! :P is there such thing is a electronic boost controller for S/C?
Old Feb 13, 2014 | 06:52 PM
Zzperformance sells one, though i have no idea how and if it works... never heard of anyone using one.
You wanna change your boost, drop the pulley size
Old Feb 13, 2014 | 06:59 PM
southal cobalt's Avatar
the stock ecu can control control boost. you need hpt software to access it though.
Old Feb 14, 2014 | 07:37 AM
blueLNFftw's Avatar
it can only reduce it
same with the pcm
Old Feb 14, 2014 | 12:56 PM
Staged07SS's Avatar
Administrator
Administrator
same with the pcm
This.
By reduction for gear changes, but it can not increase it like on a turbo car.....
Old Feb 15, 2014 | 12:38 AM
This.
i assumed that was common knowledge lol. but i can see where a turbo guy could get confused
but actually, you can limit either 1st, or 2-5 gears, or inhibit boost all together.
you can even limit it due to iats, tcs, cot. the list goes on.
Old Feb 17, 2014 | 11:09 AM
blueLNFftw's Avatar
With HPT, yes. IDK what that funky supercharger controller ZZP sells can do though.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
Gabriel94
Sep 17, 2015 08:18 PM
shawnsseries
Sep 10, 2015 08:29 PM
