Forced Induction Turbos/Superchargers
Official Dejon Piping Install Thread!!!
Old Aug 16, 2010 | 09:22 AM
  #51
slowbalt84's Avatar
Originally Posted by WV-CobaltSS/SC
question.. what is the lil filter for?????
doesn't look like a filter. that looks like a vacuum reducer. Don't think i would use that
Old Aug 16, 2010 | 09:33 AM
  #52
iboost's Avatar
I didn't use it
Old Aug 26, 2010 | 03:38 PM
  #53
Godly's Avatar
Why isn't this in the how-to section? I looked everywhere for this
Old Sep 3, 2010 | 05:30 PM
  #54
paintballerr78's Avatar
with my pipe where the bov pipe connects to the pipe coming off the turbo it always shoots out after i boost 3-4 times i always have to reconnect it back together how can i stop this from happeneing
Old Sep 4, 2010 | 10:46 AM
  #55
turbohornet88's Avatar
zip ties didnt work?
Old Sep 14, 2010 | 05:54 PM
  #56
iTwitch's Avatar
Im followed this set up, and it flutters...Im lost? I tried other ways of setting up my BOV. It doesnt make noise anymore. Im guessing maybe I messed up my BOV? Not having it properly set up?
Old Sep 15, 2010 | 04:29 PM
  #57
i put the t valve on the intake manifold and it doesnt do it anymore. I think these cars all act diffrently though. If it doesnt work for you try moving your vacuum hoses around until you find the rite combination. GL
Old Sep 20, 2010 | 03:19 PM
  #58
Sp33dyG's Avatar
sub. on finding out how to fix flutter problem
Old Sep 20, 2010 | 03:21 PM
  #59
iboost's Avatar
I only had flutter when I had the block off plate. When I took off the block of plate...T'd into the line that goes to the bpv and ran that to my bov...flutter when away
Old Sep 21, 2010 | 01:14 AM
  #60
iTwitch's Avatar
I had a bad BOV haha. I changed out the HKS for another one and it works perfectly.
Old Sep 21, 2010 | 11:06 AM
  #61
skuruc's Avatar
Sweet dis u find out what went bad with the old hks?
Old Sep 21, 2010 | 06:49 PM
  #62
iTwitch's Avatar
To be honest with you, I never took it apart yet. In fact, Im going to do that right now.
Old Oct 20, 2010 | 05:46 PM
  #63
O9cobaltSS's Avatar
if im still at the stock 15lbs do i need the upgraded couplers?
Old Oct 20, 2010 | 07:46 PM
  #64
iboost's Avatar
nope. i wasnt on silcone couplers till a couple weeks ago n i run 25psi
Old Oct 20, 2010 | 07:48 PM
  #65
O9cobaltSS's Avatar
k good to hear, never poped off once?
Old Oct 20, 2010 | 07:50 PM
  #66
iboost's Avatar
ive popped off my aftermarket coldside once but thats cause it was only half one the intake mani lol. havent since
Old Oct 20, 2010 | 07:52 PM
  #67
O9cobaltSS's Avatar
k sweet, thanks
Old Oct 20, 2010 | 07:53 PM
  #68
iboost's Avatar
no problem man
Old Nov 13, 2010 | 02:47 AM
  #69
BK05SS's Avatar
any fitment issues? Did your piping come with all the materials necessary?
Sub'd for January
Old Jan 26, 2011 | 08:18 PM
  #70
shawnmr's Avatar
help
i need to see what im doing wrong......i have the same set up except the mas is relocated and i ran my vacumn and tee as stated above but vince is having trouble tuning in....he said For some reason, the turbo is over-reacting to the boost control solenoid.....everytime i run it to full boost and shift when it blows off i get the overboost code.....it does this on both the stock 15 psi and the traction control at 24 psi......i also have a turbo xs rfl.........do i need a block off plate any help would be great so i can get this running and the tune done.
Old Jan 26, 2011 | 09:04 PM
  #71
kidcrash603's Avatar
If you have a Blow off valve, you need to get a block off plate for the bypass valve. while it COULD work with both, it makes it a nightmare to tune and in some cars can never be tuned correctly.
Old Jan 27, 2011 | 04:57 AM
  #72
shawnmr's Avatar
ok thanks i will get one............so i just but the block off plate on and use that vacumn line to go to the new bov and leave the other lines how they are then?
Old May 21, 2012 | 08:56 PM
  #73
roadrunner132's Avatar
why In the picture is the vacuum hose hooked to that black box? Is that different than hooking it to the intake manifold?
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
717ssbalt
Oct 2, 2015 04:01 PM
