Forced Induction Turbos/Superchargers
Port and polish on m62!!
Old Apr 27, 2012 | 09:41 AM
briank6102's Avatar
I finally got to porting and polishing my m62 last night.. Wanted to post pics so everyone could see and give there opinions.. What do you guys think?
Before...
And after!!
I drove it about 5 minutes last night so I haven't had much time with it but I can feel the low end torque more so that's good.. Also noticed iat2's were a bit lower..
Old Apr 27, 2012 | 09:45 AM
briank6102's Avatar
I know the outlet is not exactly straight.. I didn't want to take too much off but now that I finished I wish I would have took more off.. Took about 1/16 of an inch off.
kdub1492's Avatar
Looks good, exactly like mine did
Old Apr 27, 2012 | 09:50 AM
Staged07SS's Avatar
Administrator
Administrator
You shouldnt touch the outlet at all....
It is matched to the degree twist of the rotors.
Your inlet porting looks very nice though.
Old Apr 27, 2012 | 10:08 AM
nhanson's Avatar
Euthanasia did...
Old Apr 27, 2012 | 10:21 AM
briank6102's Avatar
I just went by the how to port on here.. All of the threads I saw said to take a 1/8 inch from the outlet.. Ive been researching this for a while now..
Old Apr 27, 2012 | 10:23 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by nhanson
Euthanasia did...
That's fine and dandy....
The outlet port is shaped the way it is for a reason.
The OP didnt remove much material so he is fine, and his inlet port job looks good.
Old Apr 27, 2012 | 10:26 AM
briank6102's Avatar
Our of curiosity... What are the screws coated with.. Whatever it is it's black.. And also, I didn't replace the sc oil I just put what was in there back in. Should I change the sc oil? It looks dirty. Same color as clean engine oil and I saw zzp has oil and it's clear. Also there sure wasn't a lot in there.. I thought it was supposed to be right below the fill plug threads but I couldn't see it..
Old Apr 27, 2012 | 10:29 AM
Staged07SS's Avatar
Administrator
Administrator
The coating on the rotors is an abratable coating....
If I had my blower apart, I would have upgraded the coupler with ZZP's coupler, and changed the oil. This way you wouldnt have to worry about anything for a long time.
http://shop.zzperformance.com/store/...r-Coupler.aspx
Old Apr 27, 2012 | 10:30 AM
1AJeremyD's Avatar
The oil is suppose to rest right below the shaft seal. If you fill it up all the way to the top of the fill plug it will come out of the seal where the shaft goes through. Right now mine is leaking out of the seal because its bad so I know what happens when you fill it up all the way lol. Rather keep the S/C going and fling some oil than lock up on the highway.
Old Apr 27, 2012 | 11:50 AM
nhanson's Avatar
Change the oil...probably pretty dark
Old Apr 27, 2012 | 06:02 PM
briank6102's Avatar
This car is just my toy.. My second vehicle I drive all the time.. Do you guys think that I should just park the car until I get the supercharger oil?? What is the zzp coupler for??
Old Apr 27, 2012 | 06:47 PM
bluebalt07's Avatar
I would just park it so you don't have to pull the supercharger again. The coupler is what connects the snout to the gears for the rotors. The stock one tends to wear out and make noise. The ZZP one is better quality so it will last
Old Apr 27, 2012 | 10:22 PM
briank6102's Avatar
Thanks for the advise guys!! Car is parked.. I have the valve cover off now painting it black to go with the car and when I get the coupler in I guess I'll be painting the sc. I saw the coupler on zzp's site for $30 and zzp oil for $10.. Should I go with zzp oil or gm? Sorry for blowing it up with questions, I'm still a newb.. Lol. I'm also looking at staging it.. Do u think a 2.8 pulley with 50# Siemens injectors, spun catted dp, mid length headers and a dual pass end plate would be a good setup? I already have a devils own methanol kit and option b. I'm just wondering how much power I'll have and how much boost I'll pull..
Old Apr 27, 2012 | 10:32 PM
euthanasia's Avatar
Before...
And after!!
What has to be done to the M62 to see any big gains is far beyound what you can do Stop while your ahead
Old Apr 27, 2012 | 10:57 PM
briank6102's Avatar
It wasn't to make more power.. It was for efficiency. I did my research and know that. This was a thread just to show before and after and start a discussion.. Thanks tho
Old Apr 28, 2012 | 12:36 AM
bluebalt07's Avatar
Look at the long tube header combo, it is awesome. Other than that setup sounds good. Just a couple things you may want to add are a stage 3 heat exchanger and the phenolic spacer. Never have to many cooling mods lol
Old Apr 28, 2012 | 07:37 AM
briank6102's Avatar
Thanks.. I'm gonna be ordering soon.. How much power did you think I would make with that??
Old Apr 28, 2012 | 07:45 AM
C_A_D88's Avatar
A good 3hp
Old Apr 28, 2012 | 08:33 AM
briank6102's Avatar
Originally Posted by C_A_D88
A good 3hp
I'm sorry.. I need to be more clear on here.. I was asking how much power will I add with the stage kit I listed above.. I want to order it today but I want to know a little more about it. Like power gains and if it's reliable..
Old Apr 28, 2012 | 08:34 AM
briank6102's Avatar
This..
Old Apr 28, 2012 | 08:41 AM
Tcobalt421's Avatar
Looks good dude keep it up!
Old Apr 28, 2012 | 12:34 PM
bluebalt07's Avatar
Most people's set ups have different components (intake, header, downpipe, etc) so it's hard to say what kinda power you will actually make. Here's a good article for reference though.
Modification recommendations for 2.0L Cobalt SS or Ion Redline | | ZZP NewsZZP News
Old Apr 28, 2012 | 01:06 PM
briank6102's Avatar
Thanks budd!! You should see the valve covers that I just painted! They look good! I'll be putting them back on today and I'll post up before and after..
Old Apr 28, 2012 | 01:12 PM
briank6102's Avatar
Talking
Thanks! Actually that's a really good reference to go by.. Looks like I should be pulling in about 260 whp!! That's gonna be fun!! I'd like to go over 300 whp tho but that's getting into cams or going turbo and that just seems a little aggressive for what I wanna do right now.. Maybe in the future tho I'll make that step!! Lol
