Forced Induction Turbos/Superchargers
ported superchager question
Old Apr 16, 2008 | 05:11 PM
nuttzzy's Avatar
is it worth paying 300 and a 4 week delay to send my supercharger to intesnse to get it ported?? i have read the how to port your supercharger fourms doesnt seem that hard but sometimes looks can be disceving ive pollished my valve cover and stuff and im pretty handy with a dremel... in yalls opinion should i attempt it or pay the money??
Old Apr 16, 2008 | 05:13 PM
Psykostevo's Avatar
Not worth paying for it. They only port it 1/8th of an inch. You can do it 1/4" and by yourself for ~$60 if you need to buy everything to do it.
I have ported 22-23 superchargers by hand for the cobalts.
First off don't spend all day grinding it away. I port in about 45 minutes. Just cut it out and then smooth it back.
If you don't know jack-**** about doing something like that then DON'T Attempt it. It's not quite as easy as just buzzing away. It's a skill/art.
Old Apr 16, 2008 | 05:32 PM
nuttzzy's Avatar
well from what i understand and i dont know the tech terms so im ganna do dummy terms.... from waht i understand take 1/8 off of each side of the little triangle and then grind the lip where the tb gose in witch its the intake side then polish smooth.....right?? but as far as takeing it apart do i have to drain the oil? and if i do id have to replace it.. but where does it drain at and stuff its not the grinding im worried about im stead with a dremel plus i get bored so i dont hurry threw things i look and take my time on critical areas you know? so do you think im capable?
Old Apr 16, 2008 | 06:11 PM
brandon2.2's Avatar
I am very interested in this ass well. I should have the tools available to me where ever I work.
I have 2.2 and I am building it, I want to mod the S/C to make it more eficient and do what I can to make good power.
I am also planning on porting the outlets on the intake manifold. Has anyone done this?? I will measure to keep them all even, but to take my time and keep it steady, I am going to do it with files.
Old Apr 16, 2008 | 06:52 PM
nuttzzy's Avatar
yeah man there some how - to's on it i was just wondering if there hidden obsticls sp? thats not discussed in the how - to's
Old Apr 16, 2008 | 06:53 PM
Area47's Avatar
Rent me! per hour
if you have never ported an intake manifold, throttle body, or a head. do not touch the blower.
Old Apr 16, 2008 | 06:55 PM
brandon2.2's Avatar
aye aye Area47
(not being a smart ass)
Old Apr 16, 2008 | 07:36 PM
nuttzzy's Avatar
well if i mess up i can always buy a tvs
Old Apr 16, 2008 | 07:43 PM
Psykostevo's Avatar
You do not need to drain the oil as long as you are careful not to break the seal between the snout and rotor assembly. All you need to do is take out the 8 bolts that hold the snout down. Stand it up and use a screw driver to "pop" the assembly up out of the housing using the extra chunks of metal as leverage. and I mean POP it out, don't dick around with it.
Make sure that you also mask off all of your sensors, stuff towels into the tube so that you don't get shavings stuck to all the muck in there, and FOR GOD SAKES, TAPE OFF THE BEARINGS! There will be enough metal shavings all over the place to turn you into Michael J. Fox overnight!
Old Apr 16, 2008 | 09:21 PM
nuttzzy's Avatar
hahaha ok i think i got it i thought the thing was filled with oil cause they'er always talking about refilling it and stuff just just slide the houseing off grind smoth slide back on easy peasy
minus the few have to's like tape lol
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
