Forced Induction Turbos/Superchargers
possible turbo or maf issue
Old Oct 22, 2009 | 10:54 AM
Zdeuce4's Avatar
i was driving last night and its been raining around here so i was taking it easy obviously.. well i got into 4th and i tapped the gas just to get about 2 psi into boost but when i did the car bucked hard. it was weird. i tried it again and got the same results
so i went home and checked to see if a piece of charge piping came off after the maf but nothings off,everythings on tight. i did see a bit of water around the maf sensor tho, so im curious if that's the culprit. water's been getting past my projectors since i installed the kit cuz the piping pushes on the bumper so one of these days i need to cover up the wires around the maf alot more just in case.
im hoping its not the turbo again, cuz i already killed my gt30r last month and replaced it with this smaller turbo. the reason i dont think its the turbo is that if i do it slowly it spools ok and doesnt buck, but if i try to go about 50-75% throttle itll go about 2 psi and then buck. im also not seeing any codes and the afr is about normal. so its perplexing me.
anyone else think its a wet maf? its supposed to warm up today so hopefully by the time i get off work if its wet, itll be dry...
Old Oct 22, 2009 | 10:56 AM
ShortStack's Avatar
Deffinatly wet maf... during a WILD rain storm, i did the same thing and it was like the engine just stopped turning all of a sudden, haha...
Old Oct 22, 2009 | 11:12 AM
Zdeuce4's Avatar
fock!!
it needs to hurry up and get hot.. im gonna wrap that sucker up tight.
Old Oct 22, 2009 | 11:13 AM
ShortStack's Avatar
It scared me i thought i hydrolocked cause of how wet it was outisde.
Old Oct 22, 2009 | 11:24 AM
Zdeuce4's Avatar
i thought i did too but i didnt drive thru deep water. i just know when i moved the headlight and looked at the maf in the fender there was some water in there. guess i need to bu more elec. tape and that wire loom
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
