Pulley Swap..?
So if I have the GM 3.0 pulley and hub on my s/c, in order to run a 2.9 pulley, would I just need to get the GM 2.9 pulley without the hub since I already have..? Also, would I need a pulley puller or any other tool to do a pulley swap..?
Cobalt & Ion ---> ZZ Performance
Thanks.
Thanks.
no, your hub will work. however, if you buy a four bolt pulley from another company you will need a new hub. and you won't need a pully puller either, it just bolts off, then the new one goes back on.
https://www.cobaltss.net/forums/2-0l...-2-9-a-231160/
how do u feel about dropping to a 2.8 instead?
yea as long as u have a pulley on the blower right now thats bolted on u can swap the pulley
if it was a stock size pulley it was pressed on and requires the pulley puller
are u running the stage 2 belt yet?
I think so, I made a thread before this but I'm not sure if I got a specific answer haha
And Yea... stage 2 pulley and belt currently. Can I just use a phillips screwdriver to take the current pulley off/on..?
but since u are on the stage kit u are probably running the 42lb injectors
if u go 2.8 go 60lb injectors
u should be able to screw the 3inch pulley off and swap the 2.9 on with the same hub
the hubs are the same size, the pulley size just changes
i went from stock pulley(pressed on) to a 2.8 bolted on with a hub
i know u have the 2.2 and when u pulley down u run into higher iat2s after acouple of pulls, as the blower is spinning faster, but additional cooling mods will help with that
but 2.9 on your current steup will be just fine, alot of guys on the stage 2 run the 2.9
maybe a retune is in store as well....boost baby haha
and i believe those are just allen bolts, so you would need an allen wrench. and that's not really special
Thanks.
Thanks.
thanks all...
BTW I am currently running 60# injectors, ZZP Stage 3 Heat Exchanger and Option B. I knew I was set up for the 2.9, just wanted to make sure that link was all I needed
patooyee
Oct 1, 2015 01:07 PM
