Forced Induction Turbos/Superchargers
Pulley Swap..?
Old Oct 18, 2010 | 04:26 PM
springerdesigner's Avatar
Question Pulley Swap..?
So if I have the GM 3.0 pulley and hub on my s/c, in order to run a 2.9 pulley, would I just need to get the GM 2.9 pulley without the hub since I already have..? Also, would I need a pulley puller or any other tool to do a pulley swap..?
Cobalt & Ion ---> ZZ Performance
Thanks.
Old Oct 18, 2010 | 04:30 PM
gwatson650's Avatar
no, your hub will work. however, if you buy a four bolt pulley from another company you will need a new hub. and you won't need a pully puller either, it just bolts off, then the new one goes back on.
Old Oct 18, 2010 | 04:37 PM
so the link I posted is all I'd need then correct..? Any special tool needed for those four blue bolts on the pulley..?
Old Oct 19, 2010 | 11:24 AM
Phyrric's Avatar
I think so, I made a thread before this but I'm not sure if I got a specific answer haha
https://www.cobaltss.net/forums/2-0l...-2-9-a-231160/
Old Oct 19, 2010 | 11:30 AM
how do u feel about dropping to a 2.8 instead?
yea as long as u have a pulley on the blower right now thats bolted on u can swap the pulley
if it was a stock size pulley it was pressed on and requires the pulley puller
are u running the stage 2 belt yet?
Old Oct 19, 2010 | 12:24 PM
I read that but didn't really answer MY question about swapping the pulley itself. Thanks.
And why go to a 2.8..? Kind of worried about internals with a 2.8...
And Yea... stage 2 pulley and belt currently. Can I just use a phillips screwdriver to take the current pulley off/on..?
Old Oct 19, 2010 | 01:43 PM
u should be fine with a 2.8, u can run another heat exchanger to help with the iat2s
but since u are on the stage kit u are probably running the 42lb injectors
if u go 2.8 go 60lb injectors
u should be able to screw the 3inch pulley off and swap the 2.9 on with the same hub
the hubs are the same size, the pulley size just changes
i went from stock pulley(pressed on) to a 2.8 bolted on with a hub
i know u have the 2.2 and when u pulley down u run into higher iat2s after acouple of pulls, as the blower is spinning faster, but additional cooling mods will help with that
but 2.9 on your current steup will be just fine, alot of guys on the stage 2 run the 2.9
maybe a retune is in store as well....boost baby haha
Old Oct 19, 2010 | 02:24 PM
Glowbalt's Avatar
yea should be able to use an allen wrench. I'm going 2.8 with 60's will let you know how it turns out.
Old Oct 19, 2010 | 02:25 PM
gwatson650's Avatar
as long as you have the stage 2 belt then yes.
and i believe those are just allen bolts, so you would need an allen wrench. and that's not really special
Old Oct 19, 2010 | 02:33 PM
SunburstSS's Avatar
Thanks.
OP, thats what i got works just fine...
Old Oct 19, 2010 | 11:18 PM
thanks all...
BTW I am currently running 60# injectors, ZZP Stage 3 Heat Exchanger and Option B. I knew I was set up for the 2.9, just wanted to make sure that link was all I needed
Old Oct 19, 2010 | 11:47 PM
awesome ness
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
