Forced Induction Turbos/Superchargers
Removing stock turbo
Old 04-22-2011, 08:29 PM
paintballerr78's Avatar
Does anyone have a how to on how to remove the stock turbo in the 2010 SS. I found a link on how to remove it but it doesnt include pics and we all know how to's are pretty much useless without pics. So does anyone have a link with pictures on how to remove the stock turbo
Old 04-22-2011, 08:50 PM
Nothin Stock
gotboost?17's Avatar
Sub'd
Old 04-22-2011, 08:57 PM
iboost's Avatar
subed'ed
Old 05-22-2011, 12:55 AM
anyone have a how to thread...Or just a thread on how to do it without pictures
Old 05-22-2011, 01:06 AM
MastaShaKe_88's Avatar
theres a how-to thread here but no pics... I'm pretty sure theres a dif one on GMSC 2...
Old 05-22-2011, 01:14 AM
ya found the one here its pretty much useless...was hoping it was easy and removing cp/intake/drain oil/disconnect battery/remove exhaust/remove oil lines/drop turbo then manifold but looks like might take awhile...Time to make a how to with pictures i guess
Old 05-22-2011, 01:16 AM
oooo do one
Old 05-22-2011, 01:20 AM
ya well attempt to...if we dont get to drunk in the process ahah
Old 05-22-2011, 01:22 AM
cbro's Avatar
haha cody you know we will
Old 05-22-2011, 01:23 AM
RKRamos's Avatar
In for your How To!
Old 05-22-2011, 01:33 AM
MS3 2 SSTC's Avatar
^^ same here!!
Old 05-23-2011, 01:34 AM
InfraRedline's Avatar
**** looks like we are making a how to Ill charge my camera...and quickly build my alcohol tolerance...lol
Old 05-26-2011, 01:45 PM
slowbalt84's Avatar
ive done a turbo swap on an ss/tc about 10 times now. if you need any help pm me anytime and i can walk u thru it. After about the 3rd time i have it down to a science lol. just a little tip, ive found that it is a lot easier if you take the rear transmission mount off. also use power tools, hand tools takes forever trust me.
Old 05-26-2011, 01:46 PM
gdubs's Avatar
i have the GM instructions
Old 07-03-2011, 09:34 PM
Hawaiian Whore's Avatar
post them
Old 03-29-2014, 04:58 PM
BaltNasty's Avatar
I know I'm bringing this thread back from the dead, but does anyone have some more information on a how too?
Old 03-29-2014, 06:57 PM
Wert842's Avatar
Use the first half of this. https://www.cobaltss.net/forums/how-guide-43/zzps-zfr-turbo-installion-287559/
Old 03-30-2014, 12:02 AM
BaltNasty's Avatar
Thanks
Old 03-30-2014, 08:54 AM
Omiotek's Avatar
Easy...remove intake and hot side pipe.remove heatshields.disconnect all sensors. Remove downpipe and o2 housing. If you remove the fuse box it makes the o2 housing easier to remove. Disconnect coolant and oil lines. You can leave the drain attached,
At that point all you should have left is to unbolt the turbo. 4 bolts it's off. That's just a quick undetailed way since I'm on the phone
Old 03-30-2014, 10:28 AM
BaltNasty's Avatar
Can you pull that line off with a pair of pliers, or is there a specific tool for it?
Old 03-30-2014, 11:13 AM
Wired's Avatar
To take the whole line off the turbo just use a hex socket and universal joint to get to the small bolt. Then you can remove the line from the plate it is connected to with a fuel line disconnect tool.
Get one at your local auto parts place. I think its the 3/8 one. In the multicolor pack it is usually blue.
Old 03-30-2014, 06:43 PM
Omiotek's Avatar
^ what he said..... use a tiny pry bar and some wiggling after you undo the 10mm botl and it comes right off
the bpv line just disconnect it or pull the bpv out and leave it connected.
Old 04-10-2014, 12:44 AM
tomj77's Avatar
just use the installing zfr howto. I did it first time, it wasn't a problem
Turbo Johnny
02-21-2019 09:41 AM
kzak104
10-11-2015 05:19 PM
Canadia
10-06-2015 10:20 PM
camaromanss1992
10-01-2015 10:51 PM
TylerJHowell
09-21-2015 06:47 PM
Quick Reply: Removing stock turbo
