Forced Induction Turbos/Superchargers
S252et question
Old Jan 5, 2013 | 07:01 PM
Igofast's Avatar
S252et question
Trying to make up my mind on the turbo I want. I'm starting lean towards the 252, but for LNF should I go with the .55 ar or .70? Someone told me smaller is better for the LNF but I'd like to get more opinions. And what's the difference between vband and 5 bolt?
Old Jan 5, 2013 | 07:12 PM
EXsoccer1921's Avatar
i would go with the .55 housing. unless you have an engine capable of high rpm and a large amount of power. you won't be able to take advantage of a .70. and the powerband you'll see with a 252 .55 will be absolutely amazing.
5 bolt vs vband is just that. downpipe connected via vband, or bolts.
Old Jan 5, 2013 | 08:46 PM
Igofast's Avatar
Ah gotcha. Thanks for the input
Old Jan 18, 2013 | 07:22 PM
shawnrandolph's Avatar
x2 it will spool much later with the 70 but will make more hp. The 55 ar is more than capable for the power 90% of people need. The 55ar is stainless and the 70ar is not also
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
