Forced Induction Turbos/Superchargers
s256ET VS. s259ET-.70AR READY GO!
Old Apr 21, 2012 | 11:24 AM
LNFssFTW's Avatar
I have everything I need for the turbo swap on my LNF besides the turbo, but only because I can't decide... My goal is to make 400-425 whp, without maxing out the turbo. The reason I am thinking a 70AR is because I want the power to be as useable as possible. I am trying to avoid tire fire from 2500rpm and up. I just need some advice on which way to go! thanks in advance guys.
Old Apr 21, 2012 | 11:28 AM
FrossB's Avatar
Thread Killer
if you only want 400 then the 256 will be PLENTY.
Old Apr 21, 2012 | 11:35 AM
LNFssFTW's Avatar
I figured. I just wanted to check with the masses. There is a few people telling me to just go big to save myself some room if I ever wanna go higher.
Old Apr 21, 2012 | 11:43 AM
Superbalt06's Avatar
I believe you can get a billet wheel for the s259 so it would probably spool as fast or faster than the s256. I used to have the s256et and it was my favorite turbo out of all the ones I've had.
Old Apr 21, 2012 | 11:45 AM
LNFssFTW's Avatar
I'm not so much worried about the spool time so much as totally maxing out the 256 to get to 400whp... I'm fine with lag, i'm used to boosted Hondas. That's why I plan on getting the biggest hotside of what is available through ZZP.
Old Apr 21, 2012 | 01:33 PM
Frogstofall's Avatar
Problem is, these aren't Hondas and cant rev to 10 million RPM. Your are probably best off with the S256et. It's got plenty of room for what you want.
Old Apr 21, 2012 | 03:17 PM
LNFssFTW's Avatar
LOL as i feel like a retard in the ecotec world. What is the max the 256 can put down?
Old Apr 24, 2012 | 01:33 AM
FasterIsBetter's Avatar
The S256ET can put down upwards of 550whp efficiently. I think ZZP has put down over 600 with it though. Thats the .55 exhaust a/r as well. I'd stick with the smaller exhaust since you have an LNF. We can only rev to around 7500 before the cam phasers stop working.
Old May 7, 2012 | 09:28 AM
Ryan@zzp's Avatar
256ext .55a/r exhaust, small turbine wheel.
Old May 7, 2012 | 09:29 AM
Ryan@zzp's Avatar
Not for long
Old May 7, 2012 | 09:46 AM
Supercharged Guy's Avatar
I'm sure the s256et will be just fine for the power you want
Old May 7, 2012 | 09:51 AM
Omiotek's Avatar
you can hit 400 even with an s252. dont understand why you want an even bigger turbo unless your going for bigger power later.
Old May 7, 2012 | 10:07 AM
BLAZIN07SS's Avatar
I'm too JDM for you
s256et. i'm hitting 19psi at 3700rpm
Old May 7, 2012 | 07:41 PM
Originally Posted by Ryan@zzp
[/B]
Not for long
Well hurry up and develop those phasers! I'll be a test car!
Old Aug 28, 2013 | 11:22 PM
taintedred07's Avatar
[/B]
Not for long
Any update on the lnf cam phasers?
Old Sep 4, 2013 | 06:41 PM
Nfamous60's Avatar
not that im tracking
Old Sep 14, 2013 | 02:40 AM
If I wanted about 450-500whp now while on stock motor(lnf) with cams/springs, BUT want to be able to hit 600-650whp later after motor build ect, would the s256et .55 be able to hit over 600whp with build motor ect or should I look into a s259et .55 so I can have that power available later on when I am built. Basically, pros vs cons of 256 vs 259.
Old Jan 13, 2014 | 10:33 PM
terry11's Avatar
This statement is not true whatsoever. Don't believe the "billet wheel hype"
Just an fyi
Old Mar 18, 2015 | 03:58 PM
Future SS Owner's Avatar
What charge piping and downpipe did everyone run with the 256et?
Old Mar 19, 2015 | 11:37 PM
Shane H's Avatar
S256et will not hit 600.
Old Mar 19, 2015 | 11:50 PM
Wert842's Avatar
Probably zzps...
Old Mar 21, 2015 | 11:00 PM
kzak104's Avatar
i would stick to a .63ar max... .55 are will come on fast
i have a pte 5558 bb with a .63ar turbine housing and the power comes on perfect. stock clutch holding on 23 psi havent gotten it on the rollers yet tho,
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Josh@ottp
Sep 17, 2015 12:03 PM
