Supercharger build thread
I was helping someone else on the board with this. They weren't using copper plugs and their throttle body wiring was messed up. They fixed both of those and all was well. Did you ask Vince to take a look at the data log for feedback? The log tells the story, not people on the internet.
But ya mine did that too and still does it. I had iridium plugs in and it was bad...really bad, I switched to my stock plugs and now it works but I get knock if I go WOT. New plugs were supposed to be here last week but never came so I am hoping soon. Also my TB wiring was loose(little purple clip was loose and cause two pins to come loose) which caused my TB issues..never really threw codes for any of it beside the P2135 code I get every once and while which sucks.
well i'm just throwing p0102, which is a maf code. I'm getting a ZZP intake and I'll clean the TB and see if that does anything
do you think that will help my stalling issue?
Last edited by redcobalt07; Jun 17, 2010 at 01:25 AM. Reason: Automerged Doublepost
exactly still the same. I cleaned the throttle body and maf sensor. New K&N typhoon intake. Exact same issues as before and stil throwing code P0102 related to the MAF, if anyone has any suggestions on how to fix it or what the issue is please let me know.
I just build my motor and I have the same thing going on . I replace my pedal sensor still got code po2135 , po300 and eng pwr reduded , i got a new TB I'll not installed it yet . so what did you find out ?
z28addiction
Sep 28, 2015 12:03 AM
