Forced Induction Turbos/Superchargers
Supercharger for dd 2.2
Old Feb 15, 2012 | 10:18 AM
the jelly man's Avatar
I have a 2006 2.2 l61 sedan. I want to either supercharged or turbocharge it. From what I have read on forums a supercharger would be the way to go. I just want a fun dd to drive. I don't want to go for massive whp numbers or anything like that just something to put a smile on my face. I have no knowledge of either of them just what little I have read from peoples posts.
If I put either of them on what else am I going to have to do, exhaust and other stuff? My car is completely stock atm. Any information wil help a lot thanks
Old Feb 15, 2012 | 01:41 PM
nhanson's Avatar
Stock exhaust is 1-5/8" so you will want to do full exhaust
Old Feb 15, 2012 | 01:54 PM
redcobalt07's Avatar
Searching would be a start. Thousands of threads on this very subject.
Old Feb 15, 2012 | 02:02 PM
I have done a lot of searching just a few questions that I couldn't find, I have read a lot o write ups on the different builds, just wasn't sure which way I should go either supercharged or turbo if it's a dd with no plans for racing
Old Feb 15, 2012 | 02:31 PM
1LowLS's Avatar
I DD my 07 2.2 SC and it's a blast and I'm spanking Hondas like a hot naked school girl(18 or older obviously) lmao. def.Want to do atleast a downpipe and catback of some sort.I have a stock SC exhaust manifold that I ported out,zzp 2.5 catless downpipe and custom 2.25 exhaust all on a 2.9 zzp pulley making 13 psi.Best 1/4 mile ET and mph is in my sig.It's def alot more fun than 150hp and I do this after every time I go WOT.
Old Feb 15, 2012 | 04:59 PM
Did you buy a kit? Or did yOu piece your s/c Together? How much did the supercharger and exhaust cost do you remember?
Old Feb 15, 2012 | 05:56 PM
1LowLS's Avatar
im about $1100-$1200 for the blower swap with a tune the exhaust I had when I was all motor which was custom made for $130 supplying my own muffler.then the zzp dp was what ever they run on the site.And I peiced mine together for about 1 month
Old Feb 15, 2012 | 06:03 PM
rcarr0327's Avatar
i turbo'd my ls for DD, i like it. :P look at sig
Old Feb 15, 2012 | 06:06 PM
evofire's Avatar
1LowLS's car is *******. I have a 2.2 supercharged sunfire, with a 3.0, and its amid 13 second car. little slower then 1lowLS's. but still super duper uber fun. i would suggest at the least a 2.25 to 2.50 exhaust, and a intake for the blower. its super fun...
i bought most of mine all together, and total with the pulley and aftermarket stuff i bought i only have about 1900 into mine.
Old Feb 15, 2012 | 07:02 PM
So piecing together is cheaper then a lit I see. What does a turbo do to the mpg?
Old Feb 16, 2012 | 05:07 AM
1LowLS's Avatar
same as blower depending on injectors and your right foot.Both are boost controlled so if cruising your out of boost but injector will play a big role too.I have 60# injectors and running 13psi on stock internals and get anywhere from 20mpg to 32mpg depending on my right foot.
Old Feb 16, 2012 | 01:50 PM
bluebalt07's Avatar
I have 60# injectors and a 3.0 inch pulley running around 14 psi and I get like 26mpg with a mix of highway and stop and go driving. Just depends on how often I decide I wanna hear the whine
Old Feb 16, 2012 | 02:01 PM
1LowLS's Avatar
exactly what I was saying.It all depends no the lead weight on your right foot
Old Feb 16, 2012 | 02:07 PM
bluebalt07's Avatar
Let's be honest here. When you go boosted, your right foot turns into a solid block of lead
Old Feb 16, 2012 | 03:07 PM
1LowLS's Avatar
gold,lead,cast iron its all the same haha.
Old Feb 17, 2012 | 08:04 PM
obviously my foot will be a little heaverier then it was when it is stock. but does just adding the supercharger do anything to the gas milege? or only because i am going to be driving it differently and more aggressive?
Old Feb 17, 2012 | 08:17 PM
drumrush's Avatar
I get 20.1 mpgs, 7 less than when i was fully bolted/tuned.
Old Feb 17, 2012 | 08:41 PM
oh wow. well im gettin 28 now so i imagine it will be about the same?
Old Feb 17, 2012 | 08:44 PM
drumrush's Avatar
Just about. But im all city with a very heavy foot
Old Feb 17, 2012 | 08:49 PM
nhanson's Avatar
Holy ****
Ill probably be the same way
Old Feb 18, 2012 | 12:48 PM
well good to know it not going to kill my gas milege to much. also putting in a cold air intake and an exhast will help a little bit right?
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
z28addiction
Sep 28, 2015 12:03 AM
