Forced Induction Turbos/Superchargers
turbo build....charge piping
Old Mar 29, 2009 | 02:42 PM
mattcossel29's Avatar
but you NEED 3" piping for the MAF, thats the only reason why it is mentioned.
Old Mar 29, 2009 | 03:00 PM
06black's Avatar
Originally Posted by Sw4y1313
2.5" should be fine, thats what most of us are running. It allows the air to move at a higher velocity so you see boost faster. What you will need to do for the best results(proof from other members) is have 3" piping for the MAF.
velocity is what will effect the maf readings in terms of maf freq, however VOLUME of the system (cross section area of all your charge pipe + IC) determines boost response.
the smaller the volume the quicker boost is created as the turbo has to move less air to reach pressure.
Originally Posted by Dayta
iv got a 54 trim
that means dick.
what turbo are you useing?
spec's?
Originally Posted by Ryan@zzp
If you are only shooting for 325-350whp you can use 2.25" IC piping. I would run my maf in a 3.5in tube depending on boost level it will max considerably easier in a 3" tube. Just use transition couplers. Then back down to a 2.5", or 2.25" pipe to the throttle body, no bigger.
judging buy what hes got going rite now, e-bay turbo and all, he'll never need a 3.5in section of maf pipe.
also 3in would be more then enough, the smaller housing would also allow for more accurate resolution on the maf.
and if you jump from small to big to small you end up "streamlining" the air through the large section due to the massive turbulence the size changes create. thus makeing MAF readings erratic at best. fluid dynamics 103.
Originally Posted by mattcossel29
Wont work.. two words.. Direct Injection
To the OP, I have done some homework on this and I read somewhere I believe 06blackg85 said you should run 2.5" on the hot side, and the cold side all the way up to the MAF, then expand do 3" and run 3" to the throttle body..
he learned that from me!
you charge pipe should be the same size as your compressor out let. as you'll never flow more then what that area will allow.
by useing that size you'll keep system volume low, thus keeping boost response high.
when you get close to the TB bump to 3in to lower the air velocity thus lowering maf freq to within range of the table and run that 3in onto the TB as to keep air turbulence to a minimum.
Old Mar 29, 2009 | 07:31 PM
I knew someone said it, i just couldnt remember lol
Old Mar 29, 2009 | 08:08 PM
xmusic_addictx's Avatar
I know its off topic, but I'm just wondering what size intercooler that is?
Old Mar 29, 2009 | 08:15 PM
FastSSinNH's Avatar
Bumpage. 340 is my guess BTW
Old Mar 31, 2009 | 10:40 AM
Weaver332's Avatar
I have heard that if you are using the stock air to water intercooler that you should run 3" piping all the way to that, is that that true? also where should i put my maf?
Old Mar 31, 2009 | 07:54 PM
Maxim_X's Avatar
Bad choice^^ It's very difficult to get the car to even idle right let alone other problems that 06black mentioned.
Old Mar 31, 2009 | 07:58 PM
ilovecars's Avatar
you got an inter cooler already and 3" is cheaper go with it.
Old Mar 31, 2009 | 08:25 PM
Dayta's Avatar
im using a different intercooler now, 2.5 exits
im hoping or 325 before my clutch decides to give
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
maliki778
Oct 1, 2015 07:39 PM
