Forced Induction Turbos/Superchargers
Turbo help!
Old Jan 23, 2011 | 09:04 PM
rcarr0327's Avatar
Turbo help!
Im installing my turbo kit and i forgot how to hook up the vacuum hoses between wastegate, bov, and everything. i need ur help fast!
Old Jan 25, 2011 | 10:14 PM
terry11's Avatar
Figure this out yet?
Old Jan 25, 2011 | 11:12 PM
rcarr0327's Avatar
yes i think so. im not gonna hook up my boost controller so i think this how i hook it up..... intake mani to bov, then from bov, to lower wastegate. and top wastegate just atmosphere (unless i want boost controller the lower goes to controller then to top of gate).
but another problem is that when i mounted my BOV it is positioned REALLLYY high and hits my hood when i close it, anyone else have this problem or have a way to fix it?
Old Jan 25, 2011 | 11:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
well you would need to move your BOV. probably should have checked that before getting it welded.
and no you have your routing wrong.
BOV and wastegate are two separate systems
1) intake mani to BOV
2) intake mani to wastegate lower port, top port vented to atmosphere(you would cut this line and put the boost controller somewhere in between)
Old Jan 26, 2011 | 08:40 AM
Ryan@zzp's Avatar
The boost control routing is all in the directions. If the bov is hitting the hood you need to rotate the charge pipe down more. The kit was designed on the the 2.4 auto. The kit does go on the 2.2-2.4 manual cars but the you might have to make some of your own adjustments.
Old Jan 26, 2011 | 08:47 AM
Jeffs 06SS 2.4's Avatar
If you dont mind me asking, how much do have in this total? I am debating a turbo kit or putting on an lsj supercharger on my 2.4.
Old Jan 26, 2011 | 08:49 AM
Ryan@zzp's Avatar
The op forgot to mention that he has a 2.2 car, so he only has one port to use on the intake and can only use it with the fitting I sent him.
OP, you have to give all the info if you want the correct answer to the ? your asking. To most people you could have a home made kit. In this case Blazin would be correct in saying you should have checked that.
Old Jan 26, 2011 | 08:53 AM
BLAZIN07SS's Avatar
I'm too JDM for you
oh, yeah I didn't realize it was a zzp kit. i have seen the fitment on a 2.4 zzp turbo kit and it was great. hopefully he gets everything sorted out
Old Feb 6, 2011 | 09:49 PM
conerboner's Avatar
I had to get a 45 degree mandrel bent piece of aluminum tubing to make my bov clear the hood on my 2.2. maybe that will help you.
Old Feb 22, 2011 | 08:42 AM
rcarr0327's Avatar
sorry i havent responded in a while. yea i got it all hookup right and i think my bov position is good too . i havent checked in a while... kit cost me like 2.2k cuz i got in on black friday but my total with EVERYTHING. head studs, gasket, gauges, etc. was around 4k..........
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
