Forced Induction Turbos/Superchargers
turbo help
Old Dec 26, 2011 | 10:05 PM
klutch814's Avatar
turbo help
alright i went and looked at my buddies turbo and snaged pics and checked shaft play. there is very little shaft play at all. just have questions.
1. what exactly model is it? i think its garret t3/t4 hybrid 50 trim
2.what are all the hoses?
3.what type of down pipe will i need?
4.is it internally wastegated?
pics:
Old Dec 26, 2011 | 10:14 PM
EXsoccer1921's Avatar
appears to be internally gated. those hosed already attached are for coolant, the long stainless one is the oil drain.
Old Dec 26, 2011 | 10:16 PM
klutch814's Avatar
so what lines connect where? and i wouldnt need a wastegate then>? could i control boost with a controller??
Old Dec 26, 2011 | 10:25 PM
i'm not familiar with the gate setups on internally wastegated turbos. but the coolant lines you'll connect to the coolant/heater hose lines on your engine. the long steel braided one will go from the turbo to the oil pan. and you can get a galley fitting to put in the rear of the block with a stainless line for the oil feed.
but honestly, if that compressor housing is a .50 a/r i can only imagine how small the turbine housing is. i would keep searching for a better turbo.
Old Dec 26, 2011 | 10:26 PM
05Slowline's Avatar
are the exhaust side dp holes stripped?
can you post the numbers off the tag? some of the numbers are hard to make out
Old Dec 26, 2011 | 10:27 PM
looks like the dp bolts on, not threaded into the housing.
Old Dec 26, 2011 | 10:31 PM
05Slowline's Avatar
Inventory sheet says Mazda Twin..list 495 LOL.....off an rx7?
Old Dec 26, 2011 | 10:34 PM
klutch814's Avatar
is that good or what? haha pics are all i have right meow.
Old Dec 26, 2011 | 10:37 PM
05Slowline's Avatar
lol not really personally i wouldn't buy it it looks like junk
TURBO INVENTORY SHEET ( ALL SALES ARE FINAL ))
466135-5
Old Dec 26, 2011 | 10:38 PM
no way to tell. looks tiny as hell. but if you want cheap, i guess you found it...
Old Dec 26, 2011 | 10:39 PM
.48 compressor housing and .63 turbine. yeah. that MIGHT make 320whp..
Old Dec 26, 2011 | 10:42 PM
klutch814's Avatar
well its only getting up to 7psi until i do internals. will it be good for what i want? im paying $300 for it
Old Dec 26, 2011 | 10:43 PM
lol that 320 number i through out there would be maxed out. 7psi on a turbo that small might actually produce less than a 2.8 m62 setup..
vahdyx's Avatar
The fins look chewed up like bad stocker lol.
Old Dec 26, 2011 | 10:44 PM
klutch814's Avatar
so your saying bigger turbo? or will this be good enough for my stock internals?
Old Dec 26, 2011 | 10:47 PM
your stock internals will be able to hold that just fine. because you won't be making much power.
Old Dec 26, 2011 | 10:49 PM
klutch814's Avatar
so what psi could i run it up to safely on stock internals/ i meen ill notice a big difference right?
Old Dec 26, 2011 | 10:51 PM
are you an lsj or le5?
Old Dec 26, 2011 | 10:52 PM
klutch814's Avatar
l61 lol
Old Dec 26, 2011 | 10:54 PM
05Slowline's Avatar
i def wouldn't pay 300 for it. i'd tell you to buy an ebay turbo first...worst comes to worst you rebuild an ebay one with Garrett internals..
Old Dec 26, 2011 | 10:57 PM
klutch814's Avatar
would it be cheaper that way? and how hard is it to do that? i dont wann eff anything up and have my car go boom haha
Old Dec 26, 2011 | 10:58 PM
have you thought about an lnf ko4 setup??
https://www.cobaltss.net/forums/part...system-267714/
Old Dec 26, 2011 | 11:00 PM
klutch814's Avatar
i have.. but i thought they werent that big?
Old Dec 26, 2011 | 11:03 PM
05Slowline's Avatar
dayta and glenn from MA both did the ebay thing with garrett internals.....i know a few fast hondas that have ebay turbos here without problems. would i use it on my car no, but looks like you're not gonna be putting down 1.5k for a turbo so..
lnf turbo would be better than that one, elecblue has an lnf setup on his 2.2 or 2.4, i think his is an upgraded wheel though.
