Forced Induction Turbos/Superchargers
turbo oil line feed?
Old Nov 29, 2008 | 04:48 PM
sprchrgdss's Avatar
Does anyone know what size oil feed fitting i need to put in the plug on the back of the block? its the plug right behind the water pump tube...
Old Nov 30, 2008 | 02:16 AM
Jn2's Avatar
Jn2
m12x1.75 is the thread size in the back of the block you need this adapter
http://www.turbotechracing.com/produ...dcategory=5623
that goes into the back of the engine, than you put in you oi line, most come with 1/8npt as its a common size and widely used size, and that should work for you
Old Nov 30, 2008 | 03:02 PM
sprchrgdss's Avatar
greatly appreciated bro
Old Nov 30, 2008 | 03:05 PM
TurboTechRacing's Avatar
Yes that is the fitting, there is actaully 6 "plugs" on the ecotec you could pull out and use this fitting for. 3 on the back and 3 on the front. The threads are a 12 X 1.75 TPI metric
Old Nov 30, 2008 | 03:08 PM
sprchrgdss's Avatar
yup i just placed my order for that adapter... THANKS guys
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
maliki778
Oct 1, 2015 07:39 PM
