Forced Induction Turbos/Superchargers
turbo whine?
Old Sep 23, 2010 | 01:50 AM
1LowLS's Avatar
turbo whine?
Have a gt2860rs turbo and recently started whining like straight cut gears.Boost and spools perfect just makes this weird a$$ noise.any thoughts?
Old Sep 23, 2010 | 02:02 AM
sundevil07's Avatar
turbo whine of death
either the shaft became unbalanced or the fins are bent
that chunk of piston prolly took something out
Old Sep 23, 2010 | 02:07 AM
1LowLS's Avatar
ya thats what we have been reading.we looked at the turbo today and it looks perfect.there was no sign of anything passing through it or impacted it but i dunno.
Old Sep 23, 2010 | 02:08 AM
sundevil07's Avatar
check the i/c pipes for oil, like more than usual. that sucks ass
Old Sep 23, 2010 | 02:10 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
How did the shaft feel? Real loose and floppy? Or all hard and tight?
Old Sep 23, 2010 | 02:13 AM
1LowLS's Avatar
shaft had very minimal play and spun perfect.
Old Sep 23, 2010 | 02:25 AM
Strange. Change the oil recently? Should check both Oil Feed and Return lines for clots... although, if you were running it low on Oil... it'd be dead already.
I've got very little experience in the Turbo Whine department. I've known of a few that did it though.
I'd consult this chart and call Garrett. It their turbo, they'll be able to help a good bit, as well.
Old Sep 23, 2010 | 02:41 AM
Tundraboarder666's Avatar
Holy **** ***** that's a lot of stuff... Guess we will see what happens when it gets torn apart tomorrow.
Old Sep 24, 2010 | 12:20 PM
BlackCobalt707's Avatar
its your car makin the sounds?
Old Sep 24, 2010 | 01:54 PM
Yeah the turbo still works just fine, but i don't want to take the risk of it coming apart in my engine... exhaust fins were scraping a little bit, just enough to throw it all off balance
Old Sep 24, 2010 | 02:07 PM
my old turbo made a sound like that, come to find out it was a boost leak tho. i doubt you got one if you say yours is fine
Old Sep 24, 2010 | 02:17 PM
I didn't have a boost leak though. It spools up just the same cant tell a difference except for the supercharger like noise it makes. you can see where the exhaust fins were cutting into the housing. Only time will kill it.
Old Sep 24, 2010 | 02:21 PM
i dunno dude. i hope it doesnt **** out on you at the wrong time
Old Sep 24, 2010 | 02:44 PM
Oh don't worry Im replacing it.
Old Sep 24, 2010 | 03:11 PM
Enuff_Said's Avatar
If your going to take it apart check the center housing rotating assembly for imperfections or damage. If you cant find any damage/imperfections on the fins that is a possible point of interest along with the thrust plate
Old Sep 24, 2010 | 03:13 PM
Read dude... lol already found the issue
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
