Forced Induction Turbos/Superchargers
Turboed l61 help
Old Apr 22, 2012 | 09:33 PM
klutch814's Avatar
Turboed l61 help
alright guys, im not tuned yet but..need some help. 1. how should my vac lines be ran i have my BOV, wastegate and boost gauge? 2. im not building any boost at all but it spools like a mother, boost leak perhaps? coolant tank is super low? also need a oil restricter but i already ordered that. im running the lnf k04 turbo with zzp mani to. thanks!
Old Apr 22, 2012 | 09:39 PM
conerboner's Avatar
don't drive it without a tune... the computer doesn't know wtf is going on lol
Old Apr 22, 2012 | 09:41 PM
dragonkingg5's Avatar
Everyone on here is going to say don't drive the car nowhere until you get tuned. Get tuned first cause with the more air coming in your ecu is probably saying wtf real loud. Shouldn't of even started it up. Double check all hoses and search for how hoses are routed. Sure there are tons of post of ppls builds that have them.
Gl
Old Apr 22, 2012 | 09:45 PM
klutch814's Avatar
i know i shouldnt have ran it im letting it sit for a week till i get tuned.. then 2 hour drive for tune\
Old Apr 24, 2012 | 03:16 PM
busa4's Avatar
all these components need a vacuum line signal from the intake manifold. you can use a large 1/4 vacuum line and then tee off to other components as you need.
Old Apr 24, 2012 | 03:42 PM
padlock's Avatar
im seriously confused as to how your car even started in the first place
Old Apr 24, 2012 | 07:25 PM
FasterIsBetter's Avatar
Yeah, for real, maf sensor readings shoulda made the ecm say "efff uuuuuu!"
Old Apr 24, 2012 | 07:28 PM
redcobalt07's Avatar
You are going to drive it two hours untuned?
Old Apr 24, 2012 | 07:41 PM
iToastie's Avatar
^^^ Bad idea
Old Apr 24, 2012 | 08:22 PM
drumrush's Avatar
Horrible idea
Old Apr 24, 2012 | 08:24 PM
ItalianJoe1's Avatar
If the piping size for the maf is close and you stay out of boost, the car doesn't know there is a turbo there.
Old Apr 24, 2012 | 09:44 PM
klutch814's Avatar
ive stayed out of boost because 1 i have a boost leak and two i dont wanna rip on it. the car reacts fin untuned.. just eats gas.. i dont drive unless absolutly necessarily .. and yea already drove it 2 hours home.. its fine. AFR's were all good to.
Old Apr 25, 2012 | 12:59 AM
Do you realize the slow destruction of the engine you are causing? It only takes the computer one false read or one little bit of acceleration and boom, you're done.
Old Apr 25, 2012 | 08:46 AM
taerae86's Avatar
this
Originally Posted by iToastie
^^^ Bad idea
Originally Posted by drumrush
Horrible idea
agreed...i wouldnt have even started it without being tuned.
and this...
Old Apr 25, 2012 | 04:09 PM
klutch814's Avatar
well right now i have a vac line going from the turbo to the wastegate..then another from intake mani with a T to my gauge and BOV
Old Apr 25, 2012 | 06:52 PM
Can you take a video of this untuned drive? Curious to see what the car is like during that kind of a drive.
Old Apr 25, 2012 | 08:41 PM
klutch814's Avatar
i have one from when i brought it back here:
also, today i recieved the oil restricter so that goes on tommrrow and i will no longer burn oil at idle. also my exahust reducer came so my buddie can weld it up and i wont be open down pipe anymore. thank you jesus was fun at first now its just head aches lol
Old May 15, 2012 | 03:07 AM
Crav3's Avatar
Wow...
Old May 16, 2012 | 11:15 PM
lil-red-89's Avatar
I would not drive this untuned 2hrs! that is beyond crazy EFF THAT
Old May 16, 2012 | 11:21 PM
nhanson's Avatar
you do know you can run turbos at 0 psi?
Old May 17, 2012 | 07:55 PM
lil-red-89's Avatar
yes i do realize this but by the previous posts the OP has put up he is not running 0psi he is just trying to stay out of boost so as i stated before i would never drive this 2hrs
Old May 17, 2012 | 09:25 PM
klutch814's Avatar
i didnt have boost because the wastegate was positioned wrong which made it stay stuck open. i drove 2 weeks like that and nothing happend. i am now trifecta tuned and running strong minus the clutch
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
maliki778
Oct 1, 2015 07:39 PM
