Forced Induction Turbos/Superchargers
weird issue with turbo
Old May 27, 2010 | 01:53 PM
Zdeuce4's Avatar
On my turbo 2.4 i keep experiencing this issue.
when i get close to redline the car feels like its bogging and backfiring.. the only way i can avoid it is to switch gears..
i tried turning down the boost controller to see if that was it, and it almost seemed like it worked. so i eventually turned it back up. im gonna try turning it back down again and seeing if that helps. im at a complete loss cuz it was fine then all of a sudden this happens and i dont even really know where to start..
my friends say its possibly the wastegate flapping or bov not working but the bov i can hear clearly and idk how to diagnose wastegate issues. any suggestions?
Old May 27, 2010 | 06:34 PM
Red05SS/SC's Avatar
could possibly be spark plugs. Which ones do you have? What are they gapped at and how long have they been in?
Old May 28, 2010 | 04:45 AM
Zdeuce4's Avatar
autolite iridiums.. gapped at wutever they came as out the box. cant remember but i just put em on like 2500 miles ago.. interesting thing to note is it started to do this right after i swapped em and tried it out.
Old May 28, 2010 | 04:51 AM
1badBlueberrySC's Avatar
most likely spark blow out... close the gap in and see if that helps... and stick to coppers they work better for turbo applications
Old May 29, 2010 | 04:34 PM
Red05SS/SC's Avatar
Yes I agree with the above. Def. use a copper spark plug and depending on boost level I would start out at like .035" and if its still the same I would make it tighter.
Old May 29, 2010 | 04:44 PM
glen229's Avatar
to rich? whats your a/f?
Old May 29, 2010 | 07:55 PM
Zdeuce4's Avatar
im pretty sure its spark blowout. after reading on other forums and seeing what others described as the symptom im sure thats wut it is. i have a set of ngks properly gapped that ill try if i cant get my autolites gapped correctly.
Old May 31, 2010 | 09:15 PM
terry11's Avatar
Too rich for that plug maybe
Old Jun 1, 2010 | 01:35 AM
Zdeuce4's Avatar
switched to the ngks and it runs great now.. car pulls hard again.
Trav3480
Oct 1, 2015 08:17 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
