Z54 or Z57
I'd say you could get away with 6500, but I have no idea how long things would last. The valve springs are relatively inexpensive and can be done with the head still installed.
If you're trying to keep the budget tight, I'd get the z54 and the valve springs. If you have a little more leeway, I'd go with the z57 and valve springs (extra US$500)
Not trying to argue as most of my info is outdated. when I got my zfr6758 the 7160 wasn’t even out yet. When guys first started putting 7160 on they all had the same statements about the power curve and that was you don’t need to ramp boost with it as it doesn’t come on as low and hard Unlike the trans killer 6758. Perhaps people have made this quicker with tuning in later years? It doesn’t make sense to me it that it would spool faster but I’m willing to listen in that regard.
im
not saying he z57 would be slow or anything but with power goals in mind faster is better for a nice low torque curve is all since peak power isn’t the goal. Biggest thing I noticed with the z54 was exactly what you were saying about making power right to redline. Very nice to hit 6500rpm and feel like there still more room up top with springs and possibly cams.
im
The EFR frames are the same size, but the compressor diameter to turbine diameter is larger for the 6758 than the 7163 (1.155 vs 1.130), the spool characteristics are essentially the same from a peak boost standpoint, but the 7163 outflows the 6758 by a bit. Even Borg Warners data says 500hp for 6758 and 550hp for 7163. Also the housing A/R will have a larger effect and I don't think ZZP has ever released that data
Now the z57 doesn't spool crazy fast but I can go off throttle vacuum to ~18psi in about 800rpm (2nd gear start at 4500), but I'm also not trying to spool faster although I think I could get that down closer to 500rpm if I wanted (I have my wastegate duty cycle pretty low in the low-mid load areas to tamper the snap boost)
DeanSsspsh (01-26-2021)
Isn’t cooldude running an lsj? Maybe I’m thinking of someone else.
ar and wastegate would make some Sense. Just early dynos/and boost curves suggested the 6758 started coming on at like 2000-2200 rpm without ramping and the 7160 was coming on at like 2500ish. That being said everyone tunes out that agressive 6758 hit and the 7160 is doing it naturally. The 7160 would be moving more air than the 6758 at that point I would imagine. Probably by 3krpm
I think the first 6758s came out with a crazy high pre-load and some people weren't dropping the wastegate table to 0s to see where the preload is actually at. My z57 came preloaded at ~14psi (going from memory, put my tuning comp away)
Now my thread is about the Z54 vs Z57 however I am curious if you could tell me the major differences between the Z57 and 6758? I know the Z57 is supposed to be similar to the 7163 but it would be good to know the difference for the added ~600$ USD.
The way I looked at it was if I get a year or two from ZZP's CHRA I can always buy a 7163 supercore (CHRA) and bolt it together.
The zfr efr core is also dual ball bearing vs the journal bearing of the z54/57
i believe they had to make the inducers 2-3mm smaller on the z series vs the zfr counterparts to make them a little more responsive to make up for the lack of ball bearings. Peak hp is a bit lower on the z series because of that.
It's also the aluminum housing vs the steel so it really is like a in house clone of the efr. Now i'm sure the ball bearings and exhaust wheel material is different, but still a decent clone
The following 2 users liked this post by ECaulk:
DeanSsspsh (01-27-2021),
ionRL_585 (04-22-2022)
#36
This thread is awesome. I started off thinking z54. Leaving considering z57 & valve springs. This is what boost is all about
AfterShok (01-28-2021)
#39
I'm assuming they are from a visual inspect they're damn close to the same thing. I haven't directly compared them by measurement (should have when my car was down and my friends STi that has a 7163, worse case I pull the z57 and then pull my friends 7163 and do a compare)
#40
At the very minimum do the z54 and valve springs, the additional 500-800 rpms is so nice. Now if you're going to be shooting for a 7500-7800rpm redline you have to get some additional parts.
#41
Gonna take a few months to get the paper right but I'm gonna do it man! For sure
I gotta figure out how to do the springs gonna do allot of research. Then I have to source the tool. I was reading today about the string method. Totally gonna figure this out. I've seen a few videos on how hard the 7163 hits @ the higher rpm range. Now I understand springs are gonna be mandatory. Thanks for the heads up ECaulk.
#44
YA man. Can't stop thinking about it. My mind is in constant boost heaven. This is gonna be nuts. I'm hoping the Indy firehawks I love are gonna still hold. Probably not. Tires are gonna get expensive!
#45
DeanSsspsh (01-28-2021)
#46
Yeah man. Even the turbo ended up having my car down for two weeks. Bolts were seized for days and I ended up having to saws all the heat shield bolts off to access 02 housing bolts. Then 2 of the turbo manifold bolts stbapped. Ordered new studs but even with heat they would extract and ended up breaking another one. Had to order a new manifold from zzp. So even though the actual install time was about 6 hours the shipping time was allot haha
#47
Damn I honestly cannot decide as they both seem like reasonable choices!
#49
@ECaulk any Z57 updates
AfterShok (05-21-2021),
DeanSsspsh (05-21-2021)
#50
I'll add to this thread, and say go with the Z57
I bought one of the first Z54's, and it grenaded in 10k miles, most of which was all highway mileage (drove for work temporarily and had work logs for proof). After a bit of a fiasco with a bunch of other units detonating, they warrantied them all and added whatever improvements they found from the failures. Warranty unit was installed early 2018.
Here we go earlier today that one bit the dust. Merging onto the highway I had it around 10psi when I was suddenly greeted with a clunk, loss of boost, and the sound of a hair dryer. Babied it home, pulled the intake, and the bearings are completely fried. This unit has over 10k, need to double check mileages.
Fortunately, oil looked clean, filter didn't really have many fines, and there doesn't seem to be anything that made it past that first 90* off the turbo.
Edit: Should check my exhaust and see if I have a turbine wheel in it
