Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
exhaust gas temp gauges
Old Mar 24, 2011 | 01:08 PM
robertmichaels's Avatar
so i wanted to know if their is a company that makes a EGT gauge that will cycle threw each cylinder??
i ended up burning up a plug and piston and dont know why, i didnt notice the wideband showing lean at all but still leaned out #4
so i want to get a header and tap in a EGT probe for each cylinder and have a digital gauge that cycles threw each one..i tired searching for one but had no luck...does something like this exsist? or what is my best option becuase i dont want to blow the new built up engine when its done....
(the car does have the GM stage 3)
Old Mar 24, 2011 | 01:15 PM
07BoostedG5's Avatar
I can make you something if you fail find what your looking for, It would consist of 4 2in wide by 1 in digital read outs marked and labeled per cylinder and molded into a pod that can mounted on the steering column in front of the gauges, each guage would have a temp sensor with a 1/8 NPT threaded mounting adaptor.
the meter looks like this, it would be a total of 4 them as they cant cycle more then one sensor
Im known as the parts engineer at my local club
Old Mar 25, 2011 | 03:42 PM
sounds tempting....do you have a picture of them in the pod and on the steering column?? and what is the price?
Old Mar 25, 2011 | 10:22 PM
ptours99's Avatar
i have that installed in my S10,it does many things besides egt very good product.
Old Apr 1, 2011 | 10:09 AM
Dezod's Avatar
Trick little piece there!
Old Apr 24, 2011 | 10:30 AM
cobalt2010's Avatar
i want one of them. how much?
Old May 5, 2011 | 12:50 PM
Dezod's Avatar
An EGT gauge?
Cheapest I carry is AEM.
AEM UEGO Controller-Air/Fuel Ratio or Lambda (6 in 1 Gauge-Type; Sensor Included)
Old May 5, 2011 | 01:02 PM
outtamymind's Avatar
thats definitely thinking outside the box. good job
Old May 5, 2011 | 01:03 PM
conerboner's Avatar
not a bad idea how much for the 4 of them and the steering wheel pod?
Old May 5, 2011 | 02:41 PM
^ alot lol the all the sensors and monitors I would sell at cost and the bezel for $100 so around 500ish for a full setup. 4 temp probes and 4 monitors with pod.
Thanks its my job!
Last edited by 07BoostedG5; May 5, 2011 at 02:41 PM. Reason: Automerged Doublepost
Old Apr 13, 2012 | 09:58 PM
YelloEye's Avatar
Could run 1 gauge hooked up to a 4 position rotary switch and run the EGT senders through that.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
