exhaust gas temp gauges
so i wanted to know if their is a company that makes a EGT gauge that will cycle threw each cylinder??
i ended up burning up a plug and piston and dont know why, i didnt notice the wideband showing lean at all but still leaned out #4
so i want to get a header and tap in a EGT probe for each cylinder and have a digital gauge that cycles threw each one..i tired searching for one but had no luck...does something like this exsist? or what is my best option becuase i dont want to blow the new built up engine when its done....
(the car does have the GM stage 3)
I can make you something if you fail find what your looking for, It would consist of 4 2in wide by 1 in digital read outs marked and labeled per cylinder and molded into a pod that can mounted on the steering column in front of the gauges, each guage would have a temp sensor with a 1/8 NPT threaded mounting adaptor.
the meter looks like this, it would be a total of 4 them as they cant cycle more then one sensor
Im known as the parts engineer at my local club
An EGT gauge?
Cheapest I carry is AEM.
AEM UEGO Controller-Air/Fuel Ratio or Lambda (6 in 1 Gauge-Type; Sensor Included)
^ alot lol the all the sensors and monitors I would sell at cost and the bezel for $100 so around 500ish for a full setup. 4 temp probes and 4 monitors with pod.
Thanks its my job!
Thanks its my job!
Last edited by 07BoostedG5; May 5, 2011 at 02:41 PM. Reason: Automerged Doublepost
Could run 1 gauge hooked up to a 4 position rotary switch and run the EGT senders through that.
z28addiction
Sep 28, 2015 12:03 AM
