'08 Cobalt Turbo gonna happen
Old Aug 17, 2006 | 05:15 PM
  #76
CobaltSonOfS.A.M.'s Avatar
Originally Posted by iso
notice the bold. this "variation" of the ls7 is the ls9 which is detuned from the ls7 and set up for boost.
also, the name blue devil has been dropped for quite a long time. last i heard was corvette ss or stingray. or possibly even z07 like the mention. i'm holding out for it to be a corvette ss.
The "Blue Devil" is the name of the test car, because it's blue and it's mean as hell, or Rick and Bob are both Duke Grads, thought to butter them up a little to give the green light.
Tuned for boost basically means: lowering the compression ratio, and making modifications for the valves, valve seats, and valve guides, and gaskets and retainers, and very little more. I went to school at the School of Automotive Machinests(S.A.M.), we had a C5-R 427 in our 98 Camaro SS(previously it was the quikest all-motor LS6 based car in the world(it was a 427 LS6) , and were the first to get the LS7 heads, before they were supposed to be released. And the Lingenfelter CNC ported LS6 heads? The port design came from this school. Ya think they know something about the LS engine? The LS7 and C5R(which the LS7 is based off of) are capable of being boosted up to 1000HP.
Old Aug 17, 2006 | 06:32 PM
  #77
iso's Avatar
iso
they also probably did the same thing they did to the 2.2 when changine it for the ss supercharged for boost. make the bore and stroke equal since that makes for the best setup of FI. in the case of the 2.2 making the bore and stroke equal caused a reduction in the displacement of the engine to 2.0 liters since displacement is based on bore and stroke as you should know. same thing with the ls7 being conformed for boost and the 'new' (not really new since it is based of the ls7) engine is coded the ls9.
also, there is no evidence that the blue devil is related in anyway to the corvette ss/stingray and many people believe that a test car for the corvette ss/stingray does not exist yet.
Old Aug 17, 2006 | 10:40 PM
  #78
SilverSS/SC's Avatar
Originally Posted by red_wing_2121
Man, now I am starting to get agitated! IT WILL BE A 6.2L LS9 SUPERCHARGED ENGINE WITH ABOUT 630 HP OR SO IN THE CORVETTE SS/STINGRAY! TRUST ME! I HAVE SEEN THE PICS OF THE ENGINE AND HAVE SEEN IT IN PERSON!
Correct you are It IS NOT a variation of the LS7 as far as the shortblock is concerned ( heads are another story ) , this is not a Vette model replacing the Z06 ....it a model well above the Z06 . Z06 will get a version of the new LS family of engines too ...the LS7 is a short lived powerplant . GM has 3 levels of supercharged LS based v8's coming ....all 6.2's . 1 HO ( LS9 ) , 1 mid level , and 1 supercharged with no intercooler .....plus the N/A 6.2 LS3 . GM's been busy ont he V8 side , hehehe.
Originally Posted by joewit
Why is everyone so sure this is going to happen in '08 ad not '09 or '10?
The Cobalts mechanical and exterior changes are model year 2008 . They dont make large scale changes like a engine outside of a scheduled update .
Old Aug 17, 2006 | 11:17 PM
  #79
06G5GT's Avatar
Originally Posted by Chizzap30
The Ion is on the Delta Platform too that is based off the Ople Astra... the plant in Springhill, TN doesn't really need to be retooled or retrained...
Just because they ride on the same basic platform doesn't mean you could just up and move Cobalt production and expect them to put it together right with no training.
Old Aug 18, 2006 | 12:10 AM
  #80
Lightbulb
A "square" motor is not he best fo FI, over quare is. Big bore short stroke makes a high reving engine, high reving engines need alot of air flow at the high RPM's, a turbo's air flow increases as RPM's go up, feeding the over square engines need for air flow. Hince the 2.0 ECOTEC being a destroked 2.2L, it has the same bore.
Look at the air cooled VW's. The simi-Halo turbo engine is a 1916cc, 94mm bore w/a 64mm stroke. With this arangment you get the absolute most bang for displacement in a turbo application. But it is not so true in a S/C application because of a superchargers linier power output.
The ultimate ECOTEC would be to use the 2.4L block with the new 2.0L Turbo crank and rods with a low comp piston and the new 2.0L with direct injection head, with the port/valve seat/combustion chamber redesigned for the larger bore. Deshroud the hell out of the valves, because, the bigger the combustion chamber the lower the compression. In theory this should work given if the parts are interchangable the way most chevys stuff is, I.E. LS 1, 2, and 6 heads with their perspective blocks.
Old Aug 18, 2006 | 12:49 AM
  #81
chipmonk212121's Avatar
http://www.jalopnik.com/cars/z07/ this is an article I found about it.
Old Aug 18, 2006 | 03:26 AM
  #82
MiSilver_SS S/C's Avatar
I worked in Springhill until 2003 and they are not closing the plant the are going to idle it for about 10 months to retool and update the body and paint shops, they will get new product but dont know what it is yet.
Old Aug 21, 2006 | 10:49 AM
  #83
Evilfrog's Avatar
Whats that sticking out from under the bumper?
Old Aug 21, 2006 | 10:57 AM
  #84
SS_SC_Cobalt's Avatar
I N T E R C O O L E R
Old Aug 21, 2006 | 11:04 AM
  #85
Evilfrog's Avatar
Yep. On a FWD delta platform car.
http://www.gvr4.com/Zeta/
  #86
plyboy-illest's Avatar
Originally Posted by Rangerondubz
Yea ive heard about that, holy shiot that thing is gonna be sooo nasty fast, as if the N/A Z06 isnt already fast enough
i knwo its going to be NUTZ!
Old Aug 21, 2006 | 11:10 AM
  #87
BaltMod's Avatar
Who punched the HHR and gave it a big lip!?!?!? Say yer sorry!!
Old Aug 21, 2006 | 12:22 PM
  #88
-Jayson-'s Avatar
the hardest pill to swallow about the cobalt get a 260HP Ecotec Turbocharged is the fact that they would be underselling there own cars. I base model GXP Solstice is 26,000 dollars, why would anyone with performance in mind by the solstice when for 4-5 grand less get a Cobalt? Yeah im sure the solstice handles alot better, but performance wise it couldnt see it being more than a few tenths of a second faster in the 1320.
With the way GM is, i could see them putting the 2.0 Turbo engine in the cars, but detuneing the car so its only got around 230HP at most. Then they will sell stage upgrades like they are doing now that gives it close to the 260HP it should be at.
If you dont believe me, think about it. GM has made a killing on the stage upgrade kits for the Supercharged engine, why would they limit themselves now? They know the car is being sold to the tuner market, the poeple will want to ugprade the performance, so they sell you less performance from the factory, but sell you more performance from the dealership.
Old Aug 21, 2006 | 12:33 PM
  #89
toydriver00's Avatar
I see them using the Saab 9 platform 2.0 Turbo. It only has 215 HP.
Old Aug 21, 2006 | 01:01 PM
  #90
bouncertime's Avatar
I agree 100%.
Old Aug 21, 2006 | 01:36 PM
  #91
Evilfrog's Avatar
Um. This is GM. They do that all the time. hell they are doing that now with the sky/solstice.
Old Aug 21, 2006 | 02:02 PM
  #92
chipsgt's Avatar
Also though, remember that the solstice and sky are a completely different market.
They are two door roadsters.
Take Mazda for example. I am not sure about the 06 line, but an 05 Miata LS, with its weak 1.8L engine sold brand new for around 24,000.00
Mazda made several other cars with comparable or more power for less.
The roadsters are targeted to a specific audience.
People will buy them regaurdless, even if there is a car with comparable power for 5,000 less.
Old Aug 21, 2006 | 03:07 PM
  #93
where did you take those pics, those are all GM test mules
Old Aug 21, 2006 | 03:26 PM
  #94
k2kwj's Avatar
Originally Posted by gonzo
By the time that happens I'm going to trade my cobalt for a charger or camaro so I'm not worried.
sounds like an idea to me, lol.
Old Aug 21, 2006 | 04:36 PM
  #95
Evilfrog's Avatar
Cant take credit for them. Just found them on another website and figured I'd share them here. Because a tubrocharged HHR is good news for those wanting a turbocharged cobalt.
Old Aug 21, 2006 | 06:11 PM
  #96
Who thinks like that ......I mean really . Lets see , do I take the economy car with a turbochrged engine , or do I want a 2 seat turbocharged roadster . Trust me saturn and sky buyers are not cross shopping Cobalts . Its all about catering to different buying styles in various markets and giving them what they want . Not about power levels verses price points . And hell yes the Sky and Solstice both would command a higher price over a Cobalt SS with the same exact engine . Compare the sophistication the 2 chassis , the interior material quality . If your theory applied , the $28K G6 GTP with the 3.6 DOHC V6 and 6 speed auto should rape a 2007 Cobalt SS/SC ....right ? .....hows a $30K Grand Prix GXP gonna beat down pretty good a $40K Caddy CTS with the sport package , who would by the caddy ? ....could go on and on .
Old Aug 21, 2006 | 07:49 PM
  #97
Also have to take into consiteration C6 Corvette(base price $44,995), 6.0 GTO(base price $33,290), and 6.0 CTS-V(base price $51,690), all have the 400hp LS2, but in a 2 seat, 2+2 coupe, and sedan, they are all rwd, but they each perform very differently, and each have their specific market.
Old Aug 21, 2006 | 07:55 PM
  #98
Don't forget that you can also get that some motor in the Trailblazer SS.
Old Aug 21, 2006 | 08:25 PM
  #99
Trailblazer SS($31,650) and SS-R(base price $39,890). And unlike the others, they share the same chassis.
Turbo Johnny
Feb 21, 2019 09:41 AM
vjoel2011
Oct 2, 2015 12:11 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
Rayray2781@gmail.com
Sep 9, 2015 10:40 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
